I've decided to ditch my go fast project due to several reasons and have ultimately gravitated towards to a new endevor.
Our Local Chicken Wing restaurant "Quaker Steak and Lube" will be hosting Asphault oval racing on Monday nights and I think this should be fun. The class I'm shooting for will be Nastruck themed. Any 1/10 scale TC with a truck body. So far they have not set limits on motor/esc and battery choices so that leaves the options wide open.
I've decided on this for a roller;
http://67.199.85.166/ae/tc5r/tc5r_home.php
It may be a bit over board but I can't see settleing on something cheaper when the price difference is only a hundred bucks from all plastic to full carbon fiber and anodized aluminum ?
Now the question is since I will be running 2s to keep it light weight and with the track being oval (not sure on straight away lenth yet) what would be a good KV choice to run with a MambaMax Pro ??
I would also consider a NEU motor for this app if I stick with this ?
This might also double as a straight line drag car out at the Friday night spot on rare ocassions with a 3s so if this is feasable BONUS.
I'm open to suggestions for the TC guys !
Thanks,
J.
EDIT; Scratch the NEU motors of the list, Just looked and everything is 5mm shaft except the 1100series and not sure they're big enough motors ?
The main problem lies with a 5mm bore 48pitch pinion being non-existant to my knowledge ?
