Go Back   RC-Monster Forums > Support Forums > Team Tekin
sudden shutdown tekin rx8
galaxy76
sudden shutdown tekin rx8 - 07.16.2010, 04:50 AM
sometimes without any reason (no jump or heating, etc.) RX8 turns off and reboots itself in few seconds.
happens to you?
rootar
rootar's Avatar
07.16.2010, 04:56 AM
get an RA number and send it back, its a common problem.
but before you do check a couple things;
all solder connections
your battery plugs
do you have steering while its "shutdown" and until it re-arms?
is the esc loose inside its case.
another thing is that it would be helpful if you could post your complete setup on here (including the rx8s settings)
ikpthegame
07.16.2010, 08:24 AM
sounds like the same thing that happened to me. they will need to replace the control board.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.16.2010, 08:29 AM
i had one like that too. after sending it back and having issues again, i decided i didn't want to run tekins anymore. it seems like they still have a few minor issues to work out.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
rootar
rootar's Avatar
07.16.2010, 01:33 PM
the newest rx8s (3 hole case) has had no reported problems other than one i got which was due to an assembly flaw when the heatsink was bonded to the control board.
they are working hard to finally get all of the issues taken care of.
galaxy76
07.19.2010, 03:32 AM
I live in Europe. send it to me is complicated
-Set-up is factory
-all solder connections is OK
-(do you have steering while its "shutdown") no
I think it's a software issue
Today I played all day and i had no problem
TekinTeamMgr
TekinTeamMgr's Avatar
08.11.2010, 10:54 PM
Shutting down is not a software issue unless the Low Voltage is set wrong.
Check the bottom of your case, the latest case has only 3 mounting holes.
  Send a message via Yahoo to TekinTeamMgr
