Confused about charging rates
ReV:-O
RC-Monster Carbon Fibre
Confused about charging rates - 07.18.2010, 10:02 AM
Hey guys,
I'm a bit confused about charging rates. I have a very capable Hyperion Duo charger, and a Turnigy 6s 5000mah lipo (this one: http://www.hobbyking.com/hobbyking/s...dProduct=10308)
I've always charged my lipo's normally, like if it's 5000mah, that's what I've charged it as. I think this is 1C charging. To fully charge my lipo, it takes around 1.5 hours, which is rather a long time.
On the lipo itself it says it can be charged up to 5C. I assume that means it will be charged 5 times quicker than charging on 1C. I wouldn't feel comfortable charging it that fast, but I would like to charge it at 2C. How would I go about doing this? Would I just need to put the capacity as 10000mah in the charger?
Bit confused here, any help would be greatly appreciated!
Thanks
Losi LST2
07.18.2010, 11:23 AM
you just need to adjust the number of amps you are charging at.
So 1c for a 5000mah battery would be 5amp charging, 2c would be 10amps
JThiessen
JThiessen's Avatar
07.18.2010, 12:31 PM
Unless you've done the most recent software update, you will only be able to charge at a max of 10A. Or, you can wire it up to use both "sides" on one battery. I've never done that, haven't needed to.
ReV:-O
07.18.2010, 01:02 PM
But 10A is the same as 2C, right? So in that case, my charger is fine.
simplechamp
simplechamp's Avatar
07.18.2010, 03:13 PM
Yes, 10A is a 2C charge rate for a 5000mah battery. And 8A would be 2C for a 4000mah, and so on.
