Looking for a battery... help?
rawfuls
roofles.
rawfuls's Avatar
Looking for a battery... help? - 07.25.2010, 09:13 PM
Well, long story.
But I need a battery.
Well you knew that!
Looking for around $20
I need a single cell, (3.7V), roughly as much mAh as possible.
Size requirements is about 90mm (length), 55mm (height, well, if it's flat, and you're overhead). 5 or so mm width
OR
75mm length, 55mm height, 20 mm width.
It's fitting in an altoids tin if you're asking.
I can do 2S, but would like it to be fairly cheap (and the single cell to fit those specs).
Here's what I'm looking at so far..
http://www.amazon.com/Tenergy-Li-Ion.../dp/B001JE8U4Y
Thanks in advance guys, person who can find such a deal, gets a cookie!
07.25.2010, 10:37 PM
Didn't do the math, but these are pretty small and cheap. Would have to put some in parallel to get the mAh you want: http://www.bgmicro.com/bat1087.aspx
rawfuls
roofles.
rawfuls's Avatar
07.25.2010, 10:45 PM
Hmm, if I stacked those, I could get about 4 of them into an altoids tin.
That's about 2680.
That would work well.
Anyone else? :D
