Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
Losi XXX-T CR SC Conversion
thzero
Losi XXX-T CR SC Conversion - 08.16.2010, 10:57 PM
So I've had this XXX-T CR sitting around for awhile. Bought it some time ago because I'd always wanted a Losi (not sure why) when back in the day we were running RC10Ts with foam on indoor tracks. Anyways, I do like the SC bodies but wasn't real thrilled about getting a new truck (and the Strike sucks) so when two companies offered conversion kits I jumped at the chance.
Two kits... Team CRC (http://www.teamcrc.com/crc/modules.p...prodID=7719120) and Exotec (http://exotekracing.com/EXOTEK_NEWS/.../31_SCX-T.html).
Probably could have done as good of job as they did by myself, wouldn't have looked as clean/professional using only hand tools. Oh well. Everyone knows what a XXX-T looks like so I won't do a lot of before pics, but here is it before...
Pretty standard stuff... MMP/CC5700 (for bashing really... may need to replace and use this in a top fuel dragster), JR 9100S servo.
And then with the Team CRC conversion...
The Team CRC conversion is nice and well done and its all carbon fiber. It makes use of the Desert Trucks front bumper and the rear bumper. The rear bumper is used to attach the body rear body mounts to. The front body mounts attach to a custom piece that is mounted to the front bulkhead.
The body posts for the front are just way too long IMO, I didn't really like it. Also by using the DT front/rear bumpers, they aren't big enough and the body just swamps them.
I just got in the Exotec kit. Its a bit more expensive but I like the body mounting system better. The rear body mounts are attached just in front of the rear shock tower onto the chassis extension. The front mounts actually attach to the front shock tower. The Exotec parts are from G10 material and are designed to match the flex of the XXX-T chassis. It uses the Strike front bumper, and you need to modify a RPM Slash 4x4 rear bumper to fit up to their kit. Both should clear the body which is great.
I'll post some more shots once I switch over to the Exotec kit parts.
Think I will end up using the body mounts and bumpers from the Exotec kit, and then the extension from CRC. Why? I think I want a solid piece that doesn't flex so that the body of the XXX-T flexes as it would when just running as a "Stadium Truck" But we'll see.
Both kits include a new front set of axles which are shorter than even the stock XXX-T (not CR) versions to meet the ROAR SC specs. Similiarly for the CR you will need to convert from the "quick change" rear hubs into the standard XXX-T hubs. Bit of a pain.
Bodies for this that seem to fit are Strike bodies and HPI Blitz Bodies (I chose the JConcepts Manta Blitz body... but I do love that new Raptor body). You need to use SC10 wheels.
