Need a semi smooth setup for revo on 4s/6s Tekin 1900kv?
R00ST
Need a semi smooth setup for revo on 4s/6s Tekin 1900kv? - 09.15.2010, 10:45 PM
I was thinking about buying a secondhand tekin RX8 with the sensored 1900kv. I decided that because I want to run 7 inch tall tires and do some slower speed crawling (along with really heavy bashing) I should probably go for a lower KV motor and gear accordingly. Since most run the 2200 I thought the 1900 would be a good KV on 4s/6s?
Being sensored should really keep it smooth on the bottom end so its not cogging horribly.
One thing that has confused me...tekin lists their 2200 motor as the "truggy" motor and the lesser KV 1900 as the "buggy" motor. Is the 1900 a smaller can or same size as the 2200?
I def dont want to go with a smaller can motor as I need all the torque I can get!
Thanks
*edit*
I was planning on purchasing a pair of each of these (so I can run both 4s or 6s) ...are they decent enough packs?
https://www.hobbyking.com/hobbyking/...00mAh_3S1P_40C
https://www.hobbyking.com/hobbyking/..._25C_Lipo_Pack
OR
https://www.hobbyking.com/hobbyking/..._Car_Lipo_Pack
