Bash RC10Gt BL powered I need suggestions!
Thunderbruiser
Thunderbruiser's Avatar
Bash RC10Gt BL powered I need suggestions! - 04.11.2006, 11:12 PM
Well i am in the notion to get her runnin so all i need are the motor mount a nice setup to get about 45-50mph outta her tops and it'll be a basher as well so i'll most likely be runnin masher tires with stiff springs so that i can go jump some stuff at the track.......i
I need help
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
Thunderbruiser
04.13.2006, 12:39 AM
come on guys i need some suggestions one where to get one so that i can jump start this project!
garage:
Monkey
04.13.2006, 02:32 AM
isnt the RC10GT a nitro convertion of the RC10T4 (i may be wrong) in that case id just get a T4
Gustav
Gustav's Avatar
04.13.2006, 05:09 AM
How many cells? that's the question. I'd go for a lehner basic,i use a 4200 on 8 and 10 cells and on 3s lipo.It's a little power house in a stadium truck.The 1920 would be the business if you want to spend that much,i've got a 10 turn that goes very well on 3 or 4s Lipo,runs a bit cooler and smoother than the basics.
Thunderbruiser
04.13.2006, 05:59 AM
well i'd run around 2 or 3 lipo's in her so the lehner would be a good motor what about? the feigao 9c or whatever it's called...i'll be running it max ride height,new-era roll cage....it's the old style chassis so i have to find a way to make the body fit and it'll be running Masher 2k's all around
Monkey: I won't get a T4 cause this car is readily available and i've spent well over what i should have in the past month on new projects and plus i got the car as a roller with engine and working radio for $67 bucks off ebay a while back.....
Also i need to find a way to strenthen the chassis more i was thinking of taking some traxxas links and mounting them along the side rails...and i need a sturdy motor mount so that i don't strip spurs!
garage:
Thunderbruiser
04.18.2006, 05:45 AM
what about a feigao s type motor like 6 or 8s? i'll be running 7-cells prolly maybe more depending......i won't run more than 12 cells though...so i wonder what'd be a good powerplant for that man batts
garage:
cart213
cart213's Avatar
04.18.2006, 06:57 AM
Contact Cold Fusion over at the radiocontrolzone forums. He sells aluminum motor mounts for $22 shipped.
Thunderbruiser
04.18.2006, 11:40 AM
hey thanks alot man...
garage:
Thunderbruiser
04.27.2006, 09:07 PM
well got my parts i'll make a new post once i get some of the parts in and make a build up thread...next week i'll need to get some parts...any ideas on what pinon to use?
garage:
Thunderbruiser
05.06.2006, 07:44 PM
i just need 5mm pinion and that should be it
garage:
