Mamba Monster - ESC isolation?
biddy
Mamba Monster - ESC isolation? - 10.23.2010, 03:43 AM
Hey guys, just wondering if the mamba monster is isolated between the BEC/Throttle Ground wire and the the main battery ground?
I ask this because I have brought the eagle tree 300A electric expander for my car data recorder and there is a specific setup for ESC's with ground wire isolation circuitry.
Basically, I wont be able to record voltage unless there is a common ground.
10.23.2010, 08:12 AM
Pretty sure its common...
Pdelcast
Pdelcast's Avatar
10.23.2010, 08:35 PM
Common with High Voltage controllers, but not car ESCs. You can't have ground isolation and a BEC at the same time.
The MMM is not ground isolated.
Thanks!
Patrick del Castillo
President, Principle Engineer
10.23.2010, 08:45 PM
I think he meant that he thinks the grounds are electrically the same point, not that isolated grounds were a common occurrance. Gotta love the ambiguous English language.
Pdelcast
Pdelcast's Avatar
10.23.2010, 08:54 PM
I think the eagle tree documentation is talking about optoisolated controllers-- which really do have completely separate and isolated grounds.
Sorry I just noticed you meant Chris' post! Sorry, I'm a little brain fried right now, in the airport in Chicago....
Thanks!
10.23.2010, 09:46 PM
No worries - I'm not offended but if you want to send me a Sidewinder SCT Combo to make me feel good thats fine to... ;)
biddy
10.24.2010, 07:32 PM
thanks for the info, saved me some time.
What is the reason behind isolated circuitry in ESC in the first place? Is it mainly for very high volt setups, or are there other advantages?
Pdelcast
Pdelcast's Avatar
10.25.2010, 08:06 PM
It's mainly for high voltage setups -- keeps the noise out of the receiver...
