Save My Insanity!!
RC-NUT
RC-NUT's Avatar
Save My Insanity!! - 10.30.2010, 11:43 PM
Hey guys. I have a converted Savage X with a KD direct drive gen 2 tranny.
I need to choose a motor and I only want to use 4s. (My other RC's use 2s LiPo and I don't want to buy 3s packs just for this truck)
With that said I'm losing my mind with all of the choices and info I've read.
So far I like:
1. Castle 2650Kv
2. KD Revolver 7L 2450Kv (44 x 65mm can)
Am I on the right path or can you offer some suggestions please.
Thanks!
10.30.2010, 11:49 PM
castle 1717 would also work
RC-NUT
RC-NUT's Avatar
10.30.2010, 11:58 PM
Now that's a 1580Kv correct? Would 4s be enough power? I noticed that motor is pretty beefy in size. (49mm x 85mm)
You'll have to pardon my ignorance. I have 22 years of RC under my belt but this brushless stuff has my head spinning!
simplechamp
simplechamp's Avatar
10.31.2010, 12:25 AM
The 1512 2650kv Castle is more of a buggy motor. I would go with a Castle 1518. Plenty of torque for a Savage and can still do just fine on 4S, and if you decide to go 5-6S later it can handle that too. Still available at the Castle sale for $65, can't beat that. You could get the 1520 or 1717 in the sale too if you decided to go BIG, but the 1518 seems like a good reasonable choice.
RC-NUT
RC-NUT's Avatar
10.31.2010, 09:55 AM
Nice! Thank you. I just spent some time on the Castle site reading about those motors. Your right I can't beat that price.
If I were to stay with 4s can you tell me what the difference would be between the 1518 / 1520 / 1717? I'm guessing the 1518 you suggested would be a little faster because it has the highest Kv rating. I'm also guessing the other 2 motors would shine better with 5s or 6s?
Am I in the ball park? The 1717 is also physically larger so I wonder what effect that has?
thzero
10.31.2010, 11:42 AM
On 4S? I'd go with a 1515 which is effectively what the Flux runs. A 1520 or 1717 you'd really have to gear up to get speed out of them on 4S. 1518 is probably a compromise as it requires less gearing but it is still closer to the 1520/1717 than the 1515. Run the numbers though Script Asylum's rc calc (http://scriptasylum.com/rc_speed/_top_speed.html) and see what the rough numbers come out too.
RC-NUT
RC-NUT's Avatar
10.31.2010, 12:25 PM
Man that 1717 is a beast. I was just watching some video's on 6s.
I may have to buy the 1717 as well as something else.
RC-NUT
RC-NUT's Avatar
10.31.2010, 12:43 PM
Castle 1518:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 49
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 1800
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.72 : 1
Total Ratio: 9.00427 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Rollout: 1.92:1
Total Motor Speed: 26640 RPM
Vehicle Speed: 48.41 mph (77.76 km/h)
Effective KV Value: 1800
KT constant: 0.75 oz-in/A
RC-NUT
RC-NUT's Avatar
10.31.2010, 12:45 PM
Castle 1717:
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 1580
Rollout: 1.92:1
Total Motor Speed: 23384 RPM
Vehicle Speed: 42.49 mph (68.26 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
thzero
10.31.2010, 12:48 PM
2 for 1. :)
RC-NUT
RC-NUT's Avatar
10.31.2010, 12:53 PM
Kershaw Designs is blowing out the 1717 for $179.00!!
I guess I can't argue with Castle for $70.00.
I have a feeling that speed calculator is not accurate for the simple fact I don't have the final gear radio of the KD direct drive tranny. They give the final ratios with a pinion and spur but not the tranny alone.
RC-NUT
RC-NUT's Avatar
10.31.2010, 03:01 PM
Thanks for the help guys. After browsing the forum for a while I've decided to go with the 1518. I really like the 1717 due to it's size but from what I have read it's a power hungry motor. My 2s 35C 3800 packs probably won't do it.
Worst case I'll buy both but I'll most likely go with the 1518. I can always bump the voltage in the future.
11.01.2010, 01:58 AM
Motor speed is low on the 1518 on 4s. I would go with the 1515 2200kv for 4s. Your gearing will have to be very high on the 1518 on 4s and will pull alot of amps on startup. The 1518 is a 6s motor, as is the 1717. I have run all of them on 6s, including the 1515. 6s is where it is at 9ask your friens, boy!!!) but if you must run 4s go with the 1515 2200. Same motor the flux uses. Motor rpm needs to be in the mid 30k rpm range for good performace when gearing a heavy MT for 40+ mph.
This needs to be stickied. I vote for this to be stickied. Would someone near the RCM store please make a sign and picket for me, I will pay you back, promise.
RC-NUT
RC-NUT's Avatar
11.01.2010, 08:49 AM
Crap. Well I placed my order yesterday for the 1518. Well I'll either spend some money on the 1515 or buy a couple of 3s packs. Probably batteries.
scarletboa
scarletboa's Avatar
11.04.2010, 12:40 AM
these batteries should really get your truck moving with a 1518. they are cheap and are very good batteries. i have over a dozen turnigy packs and they have done better than even my neu-energy packs.
