Will opening up an MMM void the warranty?
josh9mille
josh9mille's Avatar
Will opening up an MMM void the warranty? - 11.19.2010, 02:51 PM
I need to open up my speed control to clean out a bunch of sand and gravel. First question is if i do open it is my warranty gone? Second question is how do you open it? Also the fan does not work any more, is that common?
bryan
bryan's Avatar
11.19.2010, 03:00 PM
No opening the case won't void your warranty.You can get a replacment fan that comes with new case halves and stickers. There are smalll plastic tabs on the sides near the bottom that release the case halves.Be sure not to stick anything to far in while trying to release them.
josh9mille
josh9mille's Avatar
11.19.2010, 03:27 PM
That is really surprising. Castle m ust be the only electronics company that will not void a waranty for that. Pretty cool!
molak
11.19.2010, 03:30 PM
Replacement fan and case
http://www.castlecreations.com/produ...ment_case.html
How to open the case
Try cleaning your fan... the gap between the rotor and stator is really tight and just a little sand can jam it .
molak
11.19.2010, 04:23 PM
as long as you dont alter any solder the warranty is OK
11.19.2010, 04:29 PM
Hence why a lot of us are die hard CC supporters
bryan
bryan's Avatar
11.20.2010, 09:09 PM
hence why a lot of us are die hard cc supporters
+1 castle creations
