Lightning GT/GTX owners?
nativepaul
nativepaul's Avatar
Lightning GT/GTX owners? - 01.03.2011, 04:40 PM
Hi there lightning lovers, can someone measure the diameter of the gear plate on the centre spur gear shaft please, I want to find out if it is the same size as the lightning diff cup and will fit Kyosho 46t plastic spurs, as a possible replacement for the centre diff in my Lightning based rallygame car.
Also what is it made of steel or alloy?
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
kostaktinos_mt
01.03.2011, 09:23 PM
i am not sure i understand all of your questions, but i can tell you that the kyosho 44t & 46t plastic spurs are a direct fit for the lightning.
the stock lightning gt spur is a 50teeth spool (not a diff) and made of steel.
  Send a message via MSN to kostaktinos_mt
nativepaul
nativepaul's Avatar
01.04.2011, 08:07 PM
I had a Lightning 2 Pro buggy that I used as a basis for my carbon rallygame car, I currently run the kyosho plastic spurs on the centre diff which is filled with 100,000 weight oil to stiffen it up.
I would like to run a spool (what HB call a spur gear shaft) instead of the center diff, mainly to save weight, but also to reduce maintenance, my question is, are the 44t &46t Kyosho plastic spurs direct replacements for the 50t gear on the lightning gt/gtx spool?
Damn, steel, I was hoping it was alloy, is the steel solid or hollow? (anyone know what it weighs? either bare or with a plastic spur gear.) if its solid I may not save much weight over the center diff and will probably try to make a carbon fibre spool to fit the Kyosho plastic spurs as I had planned to before I heard these were available, I'm not sure how carbon diff cup connections will hold up, if they fail this will be a good alternative assuming the Kyosho plastic spurs fit.
Lots of boats.
fastelectrics.net
