810 Build
reno911
Smelly Nitro meet your maker!
reno911's Avatar
810 Build - 01.14.2011, 02:30 PM
Tried to sell the SCTen didn't happen, so I am going buggy. Placed an order for some parts and started tearing her down. Thought I would start a thread to show this.
Started as:
Then slowly to:
Got to this:
More pics to come. Oh and SCT parts are for sell!
reno911
reno911's Avatar
01.30.2011, 05:08 PM
So I haven't really got to spend some time on this one in a bit so I finally got around to tearing it apart. I redid the diffs as well with some green slime to hopefully prevent the slight leak I had. Got fresh towers and bulkheads. As well as some other goodies, are to come.
This is the left overs from the SCT conversion. Any one want them let me know, think cheap.
reno911
reno911's Avatar
02.01.2011, 04:18 PM
So after seeing the capability of some of the new Castle SCT motors I think I am going to go towards a 2s power plant for this guy... Should be interesting...
76Bentley
02.03.2011, 05:30 PM
Man I am watching your thread, I have been wondering the same thing about the 2s. My buddy has the SCT set up in CRT and he says it lights it up, so I am thinking it will on the 810.
reno911
reno911's Avatar
02.04.2011, 06:56 PM
Well I decided for the time being to go with Castle's 2650 with the MMM on 3s for the time being. If I start tearing up output cups, I think I will switch to 2s and a 550 size. Ultimately I like the idea of 2s because I have some pretty nice packs already.
Oh, and she is pretty much done, so I will get some pictures up later this weekend.
76Bentley
02.04.2011, 07:08 PM
OK sounds good, look forward to seeing the pics.
reno911
reno911's Avatar
02.06.2011, 01:44 AM
Just ordered two 3s Hardcase lipos from Hobbyparts. I am going to try their new Sky Lipo Hardcases. So looks like 3s is here to stay. Similar to the weight of the Ve8 so I don't see the hurt in it. Besides, I here with the new Short Coarse production model they are going to be making some upgraded outputs.
I already have my eyes on the aluminum goodies, like the machined shock caps.
reno911
reno911's Avatar
02.06.2011, 02:27 PM
As promised some pictures of the completed buggy...
Here is the link to it's power source, which I should have some time this week.
http://www.hobbypartz.com/77p-sl5000...-hardcase.html
More to come once I get everything tuned in. I still need to get ahold of a PT and get it in there as well.
reno911
reno911's Avatar
02.06.2011, 02:30 PM
Oh and this stuff is freaking awesome would highly recommend for use on our hobbies ESC's or anything that needs to be mounted.
I am using it to hold the MMM down, from a bench test scenario it hasn't moved under all of my testing, I.E. tugging, wrenching, pulling, etc.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.06.2011, 02:50 PM
Buggy looks great, can you post a parts list plz ?
I bought the aftermarket 17mm hubs and their sloppy, hows the 810 hubs fit ?
De-anodized can looks good also, I did the same with a 1512 1800kv mill. I like the Castle green but in some Rc's just clashes to much. Silver is nice.
I run my 10T on 3s and NEU 1512 2550kv and it's a bulllet, you'll appreciate the light weight and power !
The loctite tape, is it clear ? It's probably very close to the Parma tape, badazzed stuff !
reno911
reno911's Avatar
02.06.2011, 03:09 PM
I tried to get all of the green off, as you can see there is still some residual left. I also attempted to polish it as much as possible.
I am not using the 810 hubs, these are old revo proline 17mm hubs that I had to dremel up a bit to get them to work, but they have zero slop and work great.
The loctite tape is clear without the red film and the stuff works wonders, I am a bit upset I never found it earlier.
As for a parts list this is the best that I can do:
Losi Ten T
RCM Ten T conversion
Castle 2650
Castle MMM
RX: Spectrum SR3100
TX: Spectrum Dx3-s
AE XP DS1015
Soon to have Sky Lipo 3s 40c 5000mah hardcase
Diffs: 70-100-30
Front and rear gold springs
Front shocks: 60ish
Rear shocks: 40ish
Wheels: aka
Tires: Proline calibers m4
Body: Losi 810
Wing: Losi 810
Specs:
Rear Camber: 1.5
Front Camber: 2
Rear toe: Stock (Fixed)
Front toe: 2
Ride height: roughly 1.15 inch
geared 18/52
All specs are rough as my set up gear is not professional.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.06.2011, 03:47 PM
Very sorry, should asked for parts list to convert to buggy.
reno911
reno911's Avatar
02.06.2011, 04:00 PM
Oh...
Basically the body, wing, hubs, and wheels/tires. Everything else stays the same.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.06.2011, 04:04 PM
Sweet and simple, thanks.
When I need a new body for my 10T I'm going this route.
Buggy body uses the same body mounts ??
reno911
reno911's Avatar
02.06.2011, 04:07 PM
Sorry you'll need those too.
