making a capacitor bank.
mjderstine
mjderstine's Avatar
making a capacitor bank. - 01.17.2011, 12:57 AM
hey guys. i am going to start using my mamba max in my SC truck build, and ordered some of these to make a capacitor bank.
have any of you made a bank before?
what are your tips for doing it, or can i just wire it up and solder away like this guy did?
what do you think?
slimthelineman
slimthelineman's Avatar
01.17.2011, 11:46 AM
We build them often at work. With caps that small you don't really have anything to worry about so solder away.
01.17.2011, 11:49 AM
I would insulate the bare wires wen you have finished the soldering. Something like hot glue or liquid electrical tape should do.
mjderstine
mjderstine's Avatar
01.17.2011, 12:30 PM
sounds good guys. i thought it would be that easy.
SeanZ0r
01.17.2011, 04:36 PM
What would the benefit be of doing this? And is it replacing the OE caps in the MM controller?
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
mjderstine
mjderstine's Avatar
01.17.2011, 09:14 PM
as far as i have read from the brains on here:
helps out with voltage spikes from the batteries.
will also help over heating of the ESC
but they can add a more scientific explanation.
it does not replace the stock caps. its wired directly to the ESC battery wires.
mjderstine
mjderstine's Avatar
01.20.2011, 10:17 PM
here's mine.
they are BIG.
i thought i only ordered 3, but i got 4! awesome.
