which motor? -
01.31.2011, 07:24 PM
hello,
i have been searching for hours on end for a setup for my hhh converted buggy for bashing with no avail. im looking for a motor which will reach around 65mph on 6s or 4s if possible . since im not going to be racing and just bashing i reckon the temperatures will be lower as the motor will not be used to much as brakes and the throttle will be more continuous.
thanks for your help
RC-Monster RC8T
01.31.2011, 08:42 PM
To reach 65 you will definitely be needing 6s to keep your amp draw lower. A CC/Neu 1515 1y 2200kv motor would be a good choice, for that mattet the Mamba Monster 2200 combo is prolly your best bet. It's one of the most reliable setups out there and one of the cheaper setups you can run short of going with hobbyking stuff that won't have squat for a warranty. This combo has pushed ~15Lb Monster Trucks to 60+ Keep in mind though with gearing for those speeds your going to need to stick to smooth surfaces, stay out of the grass. Driving through grass puts a ton of extra load on a setup and is an easy way to burn something up if you don't have the right setup
01.31.2011, 10:20 PM
I would go with the cc 2200/mmm combo on 6s. You might get 65 out of the 2650 motor and 4s but you will need some good lipos and the motor will get hot. The 2200 on 6s is proven.
Just wondering, have you ran a 1/8 buggy at 65mph? It is alot faster than you think, and you need some big areas to run (like acres) to not be on the brakes all the time.
01.31.2011, 11:57 PM
i still for the life of me can not understand why everyone wants a buggy made for the DIRT to go that fast. If you wanna go fast get an ONROAD car. I think its pretty much retarded, but hey, whatever creams your Twinkie i guess.
02.01.2011, 03:20 AM
im sure when bashing i dont reach 65mph, but a car that can reach 65mph is completely different to a car that can only reach 40mph.
i know about the castle motors and i have them in lots of cars but i want to try out tekin, any recommendations
Supermaxx
02.01.2011, 04:39 AM
Tekin 2250 truggy motor with an RX8 since you want a Tekin like you said.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
02.01.2011, 07:36 AM
What gearing would I need?
02.01.2011, 10:02 AM
rm, google "rc speed calculator" :-) Then use a temp gun... often
02.01.2011, 12:46 PM
i have done so but already but its no use realy, rc speed calculator does not tell you what temperature you will be running at so for all i know i can run a 30t pinion and 20t spur. also with a tekin the timing can be adjusted which is another variable which the calculator doesn't take into account
of course i could just do some trail and error but i need a motor to base it on first, i could buy a 2650kv for example only to find out later that i cant run high enough gearing for the speeds i want as it gets too hot
thanks
02.01.2011, 12:50 PM
Try this version of the calculator: http://scriptasylum.com/rc_speed/car_setup.html
It will suggest a setup based on your input, and then allow you to tweak the values while showing (via color code; red=bad, orange=ok, green=good) the probable result.
02.01.2011, 03:49 PM
From my own experience converting over a buggy to 1/8 on-road they are almost the same thing. Basically it's different shock tower, shocks, wheels and body.
And yes, it all comes down to what you enjoy. You pay for it, so you do what you want with it. Whether that's making a buggy into an on-road speed demon, or a TC3 sedan into an off-road rally car. I think it's cool when someone takes a vehicle designed for one purpose, and modifies it to do something else. Takes creativity and innovation.
2 KiloWatt RACER
02.01.2011, 05:30 PM
There is no point going with more then 10 degrees with 4 pole motors. I've tried 15 degrees a few times and didn't see a difference in speed. Just alot more motor heat. It's just waisted power. You can gain alot with timing when using the roar motors, but not with motors that are allready as efficient as can be.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
02.01.2011, 07:05 PM
Originally Posted by simplechamp
From my own experience converting over a buggy to 1/8 on-road they are almost the same thing. Basically it's different shock tower, shocks, wheels and body..
That is true.
I cant even drive my stock savage on pavement on 6s, it goes by soo fast and is almost out of sight in a matter of a few seconds, and that is what like 45-50mph realistically? I couldnt immagine driving anything faster. I know buggies handle better at these speeds, but really its impossible to drive unless you are following in a helicopter or something. Call me strange but it just seems like a "who's junk is bigger (or smaller) contest".
2 KiloWatt RACER
02.01.2011, 07:25 PM
Speed runs are cool in my book. It's dragracing without the timing system and track. Speedruns for some is 40mph and for others it's 80mph. For Nic Case, well you know he has no limit.
Personally I can't do more then 80mph up and down the street at my house. I will run out of braking area.
Building a speed run car or dragster, is surely not an easy task. Takes alot of time and money to build one and to keep it running. And for my basher I have a 25mph Team Magic buggy. Therefore I have both and small and large "junk".
02.01.2011, 09:13 PM
thanks,
although the calculator is a nice idea in theory it doesn't really work, it says my current setup is unrealistic yet its running very cool and very quick
