Lipo charging question
nastety92
Lipo charging question - 02.17.2011, 02:31 PM
I have a new to me set of Reedy 2s 5000mah 35c lipos.
When I go to charge these what amp rating should they be charging at?
Also, what is the difference from charging them at 1.00amp compared to 5.50amps?
Thanks for the help,
Nick
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.17.2011, 02:36 PM
I can't find anything that says they are fast charge capable, so stick to a 1C charge rate, which would be 5A since it's a 5000mAH pack.
A 1A charge would be 1/5C rate. The only difference is it would take 5 times as long to charge your battery.
Either way triple check that the charger is set for a 2s lipo pack.
nastety92
02.17.2011, 02:45 PM
Thanks for the help, I appreciate it.
I just checked it is set for 2s but I had the option to switch the amp charging rate and I wanted to make sure it was right before I started.
Thanks again,
Nick
What's_nitro?
02.17.2011, 11:37 PM
No problem man. Enjoy the world of BL/LiPo!
