how to reverse a servo in this application?
mamba max1
mamba max1's Avatar
how to reverse a servo in this application? - 02.23.2011, 02:43 PM
Hey all,
Long story short, I made a swiveling camera mount attached via a Y harness to my steering servo. Made it this way so that the camera faces where the truck turns. Only problem, is the cam mount servo runs reverse to my steering direction. Because of how its hooked up, reversing its direction via my remote wont work. I know I could buy a servo reverser, but I'd rather save my money. So, is there a way I can reverse something in the servo by soldering? I'm fairly decent at soldering so I'm not afraid of attacking the circuit board (plus the servo is a cheepie)
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.23.2011, 03:05 PM
Point the servo horn 180* from where it is now. Then it will "pull" the camera where it now "pushes" it. A picture would help, too.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.23.2011, 03:22 PM
Maybe remove the black and red wires from the plug and reverse them
alport
02.23.2011, 03:27 PM
not reversing plug wires but you can reverse servo motor wires . I assume it will work and not hard to do.
J57ltr
02.23.2011, 03:49 PM
I think that would not work because the feedback would be looking for it to be in another position. It would be like having your steering servo reversed on your radio and as you take off it drifts a little left so you turn right and it goes further left so you add more right until you slam into the retaining wall. (like I did drag racing).
It would make more sense to switch the 1 and 3 terminals on the pot, since it's the feedback device, I think.
Jeff
02.23.2011, 03:53 PM
Buy a servo reverser, they are not that expensive, and most I have seen have a pot so you can center the 2nd servo independantly of the 1st (but you must center the 1st servo 1st).
I had to use one on my 6x6 maxx.
02.23.2011, 04:08 PM
Does your radio have a channel mixing feature? If so, hook the camera swivel servo to CH3, slave CH3 to CH1 (steering), and then reverse the rotation of CH3 via the radio.
Other than that, changing the linkage like What's nitro suggests would probably be the easiest.
What's_nitro?
02.23.2011, 04:17 PM
I think he might have the camera attached to the top of the servo (no linkage)... In which case you would need a servo reverser or have to do some internal work on the servo to reverse it.
mamba max1
mamba max1's Avatar
02.23.2011, 06:48 PM
I do have the camera attached to the top of the servo. I don't mind doing internal work on the servo....just need to know what to do.
What's_nitro?
02.23.2011, 06:51 PM
If you want to modify the servo, I think you just need to reverse the potentiometer leads. Usually it's the two outer-most leads of the 3, assuming the wiper is the center lead. That will make the servo spin the opposite direction.
noir522
02.26.2011, 01:36 PM
minimun soldering "how to reverse your servo"
http://www.youtube.com/watch?v=EK_FdRTenl0
http://www.youtube.com/watch?v=_bkZcOS32Uc
What's_nitro?
02.26.2011, 01:58 PM
Ahh OK so the motor wires need to be reversed, too. I thought the CPU in the servo would detect which way to spin the motor based on the POT signal, independent of the signal it recieved from the Rx.
mamba max1
mamba max1's Avatar
02.26.2011, 03:42 PM
Originally Posted by noir522 View Post
Thanks for those links! I had actually reversed my motor on a different servo, but it didn't work. now I know why.
simplechamp
simplechamp's Avatar
02.26.2011, 07:40 PM
I wouldn't do that. At the least it won't work, at the most it will fry the servo.
02.26.2011, 07:58 PM
@simplechamp: Yikes, I missed that! You're right, that will blow the servo internals. Can't forget a servo actually has an ESC and motor in one package, not just a motor. It would be like hooking a real ESC backwards.
I still think channel mixing is wayyy easier than all that modding... that is if the radio supports it.
