Spektrum / JR servo issue
Spektrum / JR servo issue - 03.10.2011, 05:14 PM
Having a strange problem with a dx6/ar6000 radio system. It does not like jr servos, namely 9100t and 8711. I have 2 of each of these servos and all 4 of them will make the receiver shut down, then restart. Does not matter if there is any load on the servo, or what channel you plug it into.
I have tried other hitec and futaba servos and they work just fine.
I am using a ccbec with a 2s lipo. Lipo is charged and the ccbec is not shutting down.
Seems like it is a signal issue, or the jr servos are putting out some sort of interference?
I tried unplugging everything from the rx save for the ccbec and the jr servo, but the problem still exists. I can unplug the jr servo and everything works as normal...
Any ideas?
