Closed Thread
Getting out while I still can. Have a few items going up for sale. Part 2
Gee
A Horse's Ass
Gee's Avatar
Getting out while I still can. Have a few items going up for sale. Part 2 - 03.23.2011, 11:20 PM
First for sale thread.
http://www.rc-monster.com/forum/showthread.php?t=29615
Link to photobucket where pictures can be found in that folder and sub folders.
http://s212.photobucket.com/albums/c...0sale%20items/
Still need pictures for the TX and Rxs
Transmitter & Recievers:
FUTABA:
Futaba 4pk Tx
Futaba R604f Rx
Futaba R603F Rx
SPEKTRUM 2.4ghz dsm TX &RX:
DX 3.0 Tx
(2) SR3000 Rx
Traxxas:
(2) Traxxas AM TX
(2) Traxxas AM RX
SERVOS:
http://s212.photobucket.com/albums/c...s%20Receivers/
(2) HPI SFL-10MG servo upgraded to MG2 servos
(1) HPI SFL-10MG
(2) HiTech Servos 5955TG
(1) HiTech HS-5998TG servo.
(2) HXT Servo
Speed Controllers (ESC )& Misc Elect items
(1) Traxxas Edition of Mamba Monster ESC & 2200kv motor (Black Motor)– No longer for sale)
(1) Mamba Monster ESC v3
(4) Mamba Maxx Controllers with External BEC
(1) Noval HV Esc
(1) HTX BEC
(2) Turnigy Receiver Switches
(1) New Still in packagePICO Switch
(2) Pico Battle switches (Remote Kill Switches & LED Controllers)
Motors,
(1) CC/Neu 1700 motor
(1) CC/Neu 2200kv Motor
(2) Neu 1515 1y .s
(1) Neu 1512 1.5d /f
(1) Medusa 3300kv
(1) Fiegoa 12s 2790kv
(1) Novak 13t Motor
Engines, Engine Upgrades. Pipe, Engine Related
http://s212.photobucket.com/albums/c...20and%20parts/
(1) Phat Dad-RC "Shread Stack" Angled Open Plenum Filter Adapter
Engines:
(1) ESP 4-Bolt Modified/ESP CHAMPIONSHIP PORTED 36mm Zenoah 30.5cc kit w/ +2mm Crank installed and Fast Eddy Ceramic bearings. Lest then 2 gallons on it.
(1) CY26cc w/ the 29cc Big Bore kit installed. This one has a few more gallons on it.
Used stock G270 Zenoah crank, Piston, & Head (was from the upgraded engine above)
Engine related items:
Brand new still in the box is a:
(1) 4-port ESP Championship Ported 36mm 29cc Top End Kit
Pipes:
(2) Meilke Side Mount Exhuast Pipe for the Baja or Rampage
(1) CPI Pipe for the Rampage MT
(3) HPI 5B, 5T and Zenoah stock Mufflers
Set of Fast Eddy Crank Bearing for Cy or Zen, Set of seal fo r the engine, gasket, roll pins.
LIPO Batteries
No Pictures yet
(2) 4s Neu 3900mAh
(2) 3s Fp 4500mAh
(2) 3s TrueRC 4000mAh
(2) 6s FP 5000mAh
(2) 2s FP 500mAh lipos
(2) Small 2-3 Lipo Trickle Chargers
(1) Turnigy 150a Lipo Balance Charger
(1) Power Supply
Assortment of RX Batteries, 6v – 2s lipo battiers
Other Misc Items:
12mm Hex Size Tire Lots:
LOT #1
(4) Dirt Hawg Tires mounted on Axel Rock Star Bead locks
(4) Dirt Hawgs mounted on offset rims
(4) Road Rage
(4) Badlands
(2) Steps
(4) Traxxas Talons
LOT #2
A set of mashers for the Jato and a
14mm Hex Size Tires Lots:
LOT #1
(4) Traxxas Talons
(4) Proline Road Rage
17mm Hex (Truck) Size Tires Lots
LOT #1
(6) New 40 series Wabash 17mm rims
17mm Hex (Buggy) Size Tires Lots
LOT #1
(4) OFNA buggy tires and rims
(4) Mismatched buggy tires and rims. The cracked rim ones are behind the house
(4) NIB JPConcepts 17mm rims
23mm Hex Size Tires Lots
Note: Lot means they are already in a box to ship out.
LOT #1:
(4) Maxx Size Badland tires mounted on Proline 23mm wheels
(4) Panther Spike Style tires mounted on Proline 23mm wheels
LOT #2
(4) 40 series Mashers mounted on 23mm Wabash rims
LOT #3
(4) 40 Series Moab XLs mounted on 23mm Wabash rims
LOT #4
(4) 40 series 23mm Wabash rims still in the package
5th Scale Tires:
http://s212.photobucket.com/albums/c...s/5th%20scale/
LOT #4
(2) HPI Sand Paddles on stock wheels
LOT #3
(4) Proline Excavator Tires Mounted on HPI rims.
LOT #2
(2) Hostile MX mounted on stock wheels
LOT #1
(2) Stock 5b SS Tires No Wheels
(2) Stock Front Wheels
(2) Stock Front Tires mounted on stock wheels
Hex Nuts
http://s212.photobucket.com/albums/c...0th/?start=all
(2) HPI 5th scale rear hex hubs + Extra Nuts
(2) HPI 5th scale Front hex hubs + Extra Nuts
(4) Dark Soul Proline 23mm Adapters Front and Rear for HPI 2x4
(4) Matching set of 17mm hubs plus a couple extra (4) Matching Blue 17mm Hex Nuts
(4) Plus 23mm adapters for Traxxas Vehicles
(1) Set of 23mm Savage Adapters two purple and two blue
(8) 2 Sets of mix matched 23mm adapter for the savage
Bag with 10mm hex (Alum & Plastic)
Bag with 12mm hex (Alum & Plastic)
Bag with plastic 17mm adapters to use with Traxxas RCs
HPI Baja Parts * Redcat Rampage Parts:
see this for sale thread
http://www.hpibajaforum.com/forum/sh...d.php?t=104167
HPI Savage Parts Lots Up For Grabs
Pictures coming will be posted in photobucket
Bag/Lot # 1:
5 used HPI Uprights some still have bearing installed
5 New HPI uprights 3 still have new bearing installed in them
Bag/Lot # 2:
2 new shock towers
2 new body posts
Used differential case
Various other plastic parts for the Savage
2 Nitro engine mounts
Bag/Lot # 3:
Lots of gears….
New 13T HPI Bevel Gear #86031
2 New Plastic Spur Gears 52T #76942
1 out of the package plastic spur
1 52t Metal Spur Gear
1 47t Metal Spur Gear
2 spare axle #86249
Original 2 speed transmission gears
6 spare dog bones various size
New Spring/Washer for Spur Gear #87042
1 new HPI Bevel Gear Set #86032
2 original savage ring gears
2 new CEN Driving 9T bevel gear #MX037
1 New HPI Alloy Diff Case #86827
Bag/Lot # 4:
Tree of small part for HPI
Used battery/rx box
Purple motor plate
Bag/Lot # 5:
New shock parts #85050
Smaller Lot with arm pins, spacers, roll pins motor plate, lower arm braces
Integy Type II Aluminum Bell Crank for the Savage
2 used bumper skid plate setup w/ custom roll bar
Bag/Lot # 6:
8 Stock XL shock with Full Force Dual Rate shock spings
4 stock Xl Shocks with black springs
4 black spring
1 spare Losi XXL shock
One used XXL shock case
One used XXL Spring
Coming soon…..
Traxxas Parts:
Coming Soon
Kyosho Parts:
Coming Soon
Also stay tuned for more…..
Turnbuckles, Differentials, Gears, Shock Parts, Differential & Shock Fluids, Nuts, bolts, tools, bearings, and Spur gears……
Pinions also oming soon. So keep yours to yourself......
Closed Thread
