Massive heat problem.
trev3813
Dsm needed
trev3813's Avatar
Massive heat problem. - 04.21.2011, 04:44 AM
Hey guys, i get bored (As you all know.. ) and created this contraption,
I can't figure out if im over geared or under geared, had it 12t to 80, overheated, tried 30/76 23/76 all over heated, just tore apart the tranny, cleaned all the gears no binding what so ever. The thing does mad donuts, (Pretty much all i wanted, boredom yet again) But i can't seem to drive it for more that a min. at most. nitro rustler base, Old crawler sides, Axial Tranny, wk rear axle. Any help? Im thinking maybe it's still massively under geared because of the tranny then axle.. Anyone got a center diff assemble with motor mount they want to part with? :P
EDIT: Castle sidewinder, 4600, 2s lipo.
trev3813
Dsm needed
trev3813's Avatar
04.21.2011, 05:06 AM
Just thinking about this now. Battery, esc, and motor are all hot.
kostaktinos_mt
04.21.2011, 08:15 AM
if the battery is hot, it looks like there is a serious issue here...
too tight gearmesh at pinion/spur?
maybe the rear axle is binding (besides the tranny) ?
last shot is a shot motor (previously overheated). can you try another motor?
  Send a message via MSN to kostaktinos_mt
Cody.McP
04.21.2011, 10:29 AM
I don't know the gear reduction of the tranny and axle but assuming it's made for a rock crawler you might be way undergeared? What kind of top speed are you getting out of it?
trev3813
Dsm needed
trev3813's Avatar
04.21.2011, 02:15 PM
Gear mesh is alright, rear axle felt fine without the tranny attached. It shouldn't be, we only ran it in a stampede for 4~6 runs.
Thats what im thinking, Top speed was decent but now im thinking motor, i tried to run it and it just "cogged" real bad but its a fully charged battery and wasn't doing it before, And it ran for a total of 10 seconds and its really hot again..
trev3813
Dsm needed
trev3813's Avatar
04.21.2011, 02:30 PM
Yep. Motor. Tried my brothers sw on my motor and it did the same thing. Need a motor now.
