Closed Thread
FS: Hyperion EOS 7i Charger, 12v 15A PS, LBA10 Balancer
FS: Hyperion EOS 7i Charger, 12v 15A PS, LBA10 Balancer - 04.23.2011, 09:01 PM
Like the title says, up for sale is a Hyperion EOS 7i charger, LBA10 balancer, and 12v 15A converted power supply.
The charger is old, but still works, I just have upgraded to a 0615 Duo so this is just collecting dust. The 7i charger is rated for 1-5s lipo/25 NiXX/1-6 lead-acid, 1-7A charge rate, 120w power limit. No LiFe setting. As you can see in the pic, I changed the input cable because I found the stock wiring too small. At some point, the wire got partially cut, so I reconnected using soldered butt-connectors (the black lump in the middle).
The power supply is a converted PC Enlight ATX unit. Rated 15A @ 12v. Will run the included charger up to its 120w rating with ease, but not sure how much beyond that. The heatsink you see on the side is where the 5v loading resistors are. The AC cord is included.
The LBA10 is rated up to 6s and 10A. It has a modded balance connector so that it will plug into pretty much any balance plug as long as it is the typical 0.1" spacing. Just make sure the black wire goes to the most negative cell on your pack.
As usual, PM for pricing. Or make a fair offer.
Closed Thread
