[SIZE="4"][COLOR="Blue"]So this is my pride and joy. It has had little use and has run like a tank. I had one bad flip in grass and now something needs rebuilt. Sounds like a diff needs rebuilt. Mamba esc/motor and everything else is flawless. I am not trying to hide anything. If I were buying this rig I would expect to go thru the whole drive-train....if your not capable of that this is not the rig for you. Instructions manuals and certificate of authenticity comes with. I will also send all the nitro stuff I have with it as well.
I dont have time to tinker and figured it would be in better hands of someone that could put it thru its paces. The rig has a beautiful conversion by RC-monster that is stock looking with limited run anodized black finish. The servo plate is carbon fiber.
I have installed a MMM and 2200kv motor that has only seen a few runs. Also has Hitec 5995 servo running the steering. Also has a beautiful Mugen body on her...simple and clean.
This rig can come different ways.
$?? as roller. Dirt cheap.
$?? with MMM / 2200 motor
Add $?? for the servo if wanted
Add $?? for the receiver if wanted.
Here it is....
