Tenshock X803 - 8 poles
Dj_Sparky
Tenshock X803 - 8 poles - 05.10.2011, 01:58 PM
"The new 1 / 8 motor being Design X803
8-pole structure 12 slot tilt
Should be more smooth" - Tenshock
Was posted by Tenshock at http://www.rctech.net/forum/electric...-motors-3.html
The X801 and X802 series have already gotten a good reputation from what I've read. Seems like they are extreme torque monsters, so this should be no different. The X802 is rated at 3500 watts!
nuz69
nuz69's Avatar
05.11.2011, 05:24 AM
I know some people here who have good results with 6 poles x801, used with the Mamba Monster and 20° timing. According to them, it's very smooth and efficient. But can the Mamba manage a 8 poles motor ?
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
simplechamp
simplechamp's Avatar
05.11.2011, 11:46 AM
It can run them, but the RPM is the limiting factor, how fast the ESC can switch the FETs. Each time you double the poles you lose half your max RPM. If the MMM can spin a 4-pole at 80k max RPM, an 8-pole would be 40k max RPM. Those are just examples I made up, not sure what the real values are. I think the true values can be found in the Castle section somewhere, not sure what thread though.
The way I see it they must test these Tenshock motors using ESCs that are similarly (or maybe even less) capable as the MMM, so I don't see any issues for most people. Most applications will be between 30-40K RPM.
Semi Pro
Semi Pro's Avatar
05.11.2011, 08:36 PM
the mmm can handle alot more rpm than you think, i rember patric talking about it, but i have yet to find the post for you.
personaly, other than outrunners i have only owned one motor with more that 4 poles and i loved it, any clue on a price from them yet?
Dj_Sparky
05.11.2011, 08:55 PM
No clue on price yet. They have some 8 pole helicopter inrunner motors with open cases here though; http://tenshock-motors.de/Tenshock-B...-Pole-TSCZ2760
Quite expensive.
