HPI Rs4 electric conversion help..
arvint
HPI Rs4 electric conversion help.. - 06.06.2011, 10:26 PM
Hey..
Friend gave me a pretty beat up rs4...and I made it a project to bring it back to life..in electric form (was nitro)...without spending over $50 (Had the electronics, motor mount got on sale..)..
AND..here's the problem...is there anyway to get that pinion to reach the spur gear?
I searched around and found something like this..but it's the wrong size bore for the motor shaft (Castle's 4 pole 5700 is 1/8" I believe)..
http://www.caswellplating.com/buffs/shaft.htm
With some recent efforts..I got the pinion even closer..
While posting this..I might try flipping the spur gear around..if that works..other wise..I still think i'd be about 1/2 an inch short..
Motor mount will not come anymore forward unless I hack away at it..
So..any thoughts?
Thanks!
EDIT:
Have flipped the spur around..about 1/2 an inch away from the pinion touching the spur..starting to hack away the motor mount...but it'll require alot of dremeling....and time...
brainanator
brainanator's Avatar
06.06.2011, 10:44 PM
Just drill a couple new holes in the chassis
edit: I guess looking at the pictures the motor mount might not squeeze in there, hard for me to tell or not.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.06.2011, 10:52 PM
You could buy some aluminum plate and make an extended chassis for well under $50. Or, make a new motor mount that fits on the existing chassis- also less than $50.
arvint
06.06.2011, 10:58 PM
Motor wont squeeze in :/
Dont have the equimpent to make an extended chassis atm either..
Is there a way to extend the motor shaft? I know I've seen them before on bigger motors with 1" shafts..
What's_nitro?
06.06.2011, 11:09 PM
I wouldn't recommend using a shaft extender unless you can fit a bearing for support near the far end of the shaft. You'll end up breaking them otherwise.
arvint
06.06.2011, 11:36 PM
That actually I can do, already have a plan for the bearing supper that the extender that can mount up in no time!
Just need to find an extenter that will work..only has to be 3-4cm long..maybe less.
mamba max1
mamba max1's Avatar
06.07.2011, 01:01 AM
You could make another shaft for the pulleys/spur gear. Make it longer on the motor side so you can mount the spur on the opposite side of the pulley.
arvint
06.07.2011, 01:42 AM
Oh hey..you know what..I'll look into that..
Good idea x)
Aussie Nerd
06.07.2011, 02:17 AM
Flipping the spur and a tekno long shank pinion with a 5mm to 1/8th bore reducer might just work. I'd be worried about snapping the motor shaft though.
Kieren
arvint
06.07.2011, 02:40 AM
Alrighty :)
Found a link for a shaft extender that will work..
But as far as the pinion..what would be a ideal number of teeth? spur gear is a 39t.
would 19/39 sound alright? (5700kv 4 pole castle system)
Planning to use a 2200mah 2s 45c lipo..also..would that provide enough amps to the system? If not..I can run to in parallel..can only fit a 100m long battery in the limited space..width is about a little less then 100m..
arvint
06.20.2011, 02:41 AM
Yes yes..I know the body didnt turn out great..was planning to have tinted windows..but i painted it at 1 in the morning..and I FORGOT to put on the masks.......... :P
Just needa get a lipo thats 110mm or less..and Im set!
Aussie Nerd
06.20.2011, 11:54 PM
Looks like the long shank pinion worked fine!
Kieren
Big House
Big House's Avatar
06.21.2011, 11:08 PM
I love you choice in models. I converted one a couple of years ago and is an on going project...it is now a 6s monster. Blew a chunk of foam and wheel off during a bench test.
ID:	10015   Click image for larger version
Name:	6s RS4 - 2.jpg
ID:	10016   Click image for larger version
Name:	Blown wheel.jpg
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
Bad bench test
Big House
Big House's Avatar
Bad bench test - 06.21.2011, 11:55 PM
Testing 6s in my Super RS4. All was well until the rear wheel blew apart. Take a look.
http://youtu.be/Wo7X3ngWJXU
CF Losi LST2
