Closed Thread
Ultimate Lst Sale
brushlessboy16
brushlessboy16's Avatar
Ultimate Lst Sale - 06.10.2011, 06:49 PM
First Up is the truck itself
-Team Losi Lst
-1 brand new differential and housing in the front
-New front center drive shaft
-Complete set of front and rear RPM suspension arms
-Brand new Steering assembly and servo savers
-2/3 skid plates are the losi hard anodized unit, the other is included in the sale but needs to be put on
-Losi Super Bolt tires, low use
-23mm dynamite wheel hexes
-trans is forward only, with a locked first gear
-quick and dirty electric motor mount
Bought this truck to make a brushless lst but never got the funding to it.
2 working transmissions, one has a mounting tab broken off but gears are fine
** both transmissions have brakes and aluminum brake arms**
1 transmission housing
3 Ti-ni 1st gear gears of various sizes
3 Ti-ni 2nd gear gears of various sizes
2 thread on clutch bells with ti-ni gears
2 standard 2 speed clutch bells (unsure of tooth count)
2 transmission input shafts
3 plastic 2 speed gears of various sizes
2 2speed hubs
2nd set of front and rear ends
What you see is what you get
-No diffs
-Standard a-arms etc
-front has aluminum bulkheads!
More suspension bits
6 shock towers
2 custom steel wing mounts
3 chassis braces
a stock bulkhead
Not shown is another set of aluminum bulkheads
7 spare shocks
9 springs
1 shock has a broken end, but is still in tact
free 50 bucks worth of shock oil!:ha:
**not shown is another pair of aluminum shock caps, and miscelaneous shock parts
Then there is a box full of little parts like clutch plates springs etc, some Ti-ni gears
Im probably forgetting something
Servo can be included with the truck for a price
I am open to trades and am very negotiable. Need this gone.
Price is lowwww
Closed Thread
