Battery question
FG101C
Battery question - 06.25.2011, 12:18 PM
I hate to start a new thread but can't seem to find an answer to my question.
I decided to convert my Baja, DDM had the kit for $475.00 w/free shipping last night.
I recently ordered a Nano-Tech 5s 4000mah 45~90c pack but it won't fit the original application.
My question is, and it seems like this would be fine, if I get the same pack, same mah and c rating but 3s I can run that and the 5s in series for 8s correct? I mean the length and width dimensions are the same for both packs so that tells me they are the same cells just one pack is 3s and one is 5s.
What do you guys think?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.25.2011, 12:30 PM
If they have the same capacity, C rating, and are the same age, it is alright to series them. I'd do a 1C cycle on each pack to check the capacity and make sure they are within ~5% of each other. If they are too far apart then one pack will hit LVC too early and be over-discharged and possibly damaged.
josh9mille
josh9mille's Avatar
06.25.2011, 12:59 PM
you can also set the LVC higher so you wouldnt have to worry about it as much
FG101C
06.25.2011, 03:47 PM
OK, thanks
