Motor connections on a 18.97
cabking
Motor connections on a 18.97 - 05.01.2006, 08:47 AM
the problem I have is that the small 3.5mm plugs keep comming out from the speedo after landing from jumps.
I have replaced the cages on the plugs but they still slip out in the end.
It is now a couple of years old so I guess there has been some wear to the tubes.
Q: Is it possible to solder the wires in, or will the heat damage something else on the board??
Serum
Serum's Avatar
05.01.2006, 11:01 AM
Considering schulzes critical point of view, that would be byebye warrantee. (they have got a heck of an excuse then..)
You can make some kind of construction that avoids this though. just think and tinker Cab!
Gustav
Gustav's Avatar
05.01.2006, 02:08 PM
The schulze 3.5mm plugs seem to fit a bit tighter than fiegaos,i know i have to have my motor wires the right way round at the moment or they're a bit loose at the controller(schulze on one end fiegaos on the other)
coolhandcountry
coolhandcountry's Avatar
05.01.2006, 06:48 PM
I had melted one of the plugs on the esc.
I soldered my directly in the tube.
I have no problems with the esc so far.
If you had it for a couple years.
I have serious doubts it is still under warranty.
I would not try to get it to hot though. If you get my meaning.
Peace!
Country
Help support the
Rc-Monster
Buy here
cabking
05.02.2006, 05:17 AM
Did it ever have a warranty?? :010:
I get your point about the heat though, I have solved it temporally with the trusted zip ties.
I have noticed some arcing on the plug too, it will have to be done soon :028:
pcnutz
pcnutz's Avatar
05.03.2006, 08:22 AM
use no more than a 40watt iron and be carefull not to spash solder, but it should be cool to attach direct
Serum
Serum's Avatar
05.03.2006, 08:56 AM
Don't use a too big iron indeed.
I thought this was about soldering cells, my original post can be ignored..
