Updated pics of my TANK
RC-NUT
RC-NUT's Avatar
Updated pics of my TANK - 08.13.2011, 09:59 PM
I haven't been on the forum in a while so I thought I would post some new pics of the 15.5 pound monster. I'm starting to realize that bigger is not always better. Granted the 1717 still throws the truck around like a mini Revo but almost every run ends with a breakage.
I have a lot more fun with the truck when it was much lighter and had a 1518 on 4s.
Anyway here are some pics.
Name:	roll cage 1.jpg
ID:	10117   Click image for larger version
Name:	roll cage 2.jpg
ID:	10118   Click image for larger version
Name:	roll cage 3.jpg
Name:	roll cage 5.jpg
josh9mille
josh9mille's Avatar
08.14.2011, 12:10 AM
Good looking truck! You built a tank for sure! lol. I bet if you used lighter wheels and tires and traded all that aluminum for stock or RPM plastic stuff you would lose weight and not break stuff all the time.
RC-NUT
RC-NUT's Avatar
08.14.2011, 12:48 PM
I think your right. I switched to the big Joes because the rims that I have use a 5 lug system with an aluminum adapter. (If that makes sense) There is no hex to strip or crack. The down side is they are heavy and have a crazy amount of traction so I either melt my slipper or snap the rear dog bones.
I have had good luch with RPM so I may swap a lot of that over.
I'm on the fence about the 1717. Sure it's big and nasty but not as smooth as some others. It's more like a low RPM on/off switch. I'm running a 23/49 and still can't keep the front end down at any speed. The top end isn't that fast but I have a hard time getting there on 4 wheels.
08.14.2011, 02:23 PM
Which chassis and motor mount is that?
RC-NUT
RC-NUT's Avatar
08.14.2011, 03:18 PM
The chassis is a FLM standard Flux upgrade. The tranny is a Kershaw Designs V2 which has the motor mount built in. However I had to have a machine shop open up the slots to accept the larger 4mm screws for the 1717.
JThiessen
JThiessen's Avatar
08.14.2011, 06:08 PM
I found the same thing after I upgraded my flux to the FLM stuff. They are currently gathering dust on my bench.
RC-NUT
RC-NUT's Avatar
08.16.2011, 06:30 PM
I just took it out for a spin and decided it was the last run. It's too heavy, too hard to drive, and loves to bend and break.
It was a fun project but now it's time for a new one.
