Knocked the teeth out...
Big House
Big House's Avatar
Knocked the teeth out... - 09.18.2011, 09:23 PM
of the rear pinion gear in my GTP. Blowing the dust off the chassis doing a few full speed runs up and down the street, I rear end sounded and shook terribly. I broke down the rear end and found that 7 teeth had been broken off the differential pinion gear. I love the power but hate the inconveniences it causes. Upgrade time.
ID:	10141   Click image for larger version
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.18.2011, 11:05 PM
True Monster. Do have the hardened diff rings?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Big House
Big House's Avatar
09.18.2011, 11:16 PM
I will soon. The gear ratio is going to be lower also. The stock is 3.30 but the new ratio will be 44/14 or 3.14.
CF Losi LST2
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.19.2011, 01:59 AM
That's actully a higher ratio then, not lower
09.19.2011, 11:08 AM
Worst part about the K series diffs, they just do not hold up all that well... I did the same on my mbx and gtp. If you shim them just right and run some good synthetic grease they last longer.
scarletboa
scarletboa's Avatar
09.19.2011, 04:03 PM
are there any diffs that are stronger that fit in an ofna lx-1e without too much modification? i know that the GTP uses the same diffs as the lx-1e, so this will be helping big house too. i have been running 4s in my buggy without issues, but i want to bump it up to 6s and a 1518, but don't want weak diffs.
Overdriven
Destroyer of Tires
Overdriven's Avatar
09.20.2011, 09:06 PM
I haven't had any issues with my LX1-e after lots of very hard running with mine, always on either a 1518 or 1520 (I had to at least try it!) on 5s. My 1st LX buggy (an old old blue chassis) conversion, did eventually chew both ring gears, but I never checked them until after the carnage either. I blame it on age and never being serviced or re-shimmed after 10 gallons of nitro and at least 2 dozen packs through it.
