Winter Project #1
DR STATIC
DR STATIC's Avatar
Winter Project #1 - 10.29.2011, 07:21 PM
SuperMaxx Project
Looking for a Winter Project!!! Check this Out!!!
Extended T-Maxx Chassis w/ HD Dogbones
HD Aluminum Front & Rear Bulkheads w/ New Braces
* Included @ No Additional Charge... Some Titanium? Hinge Pins
Extremely Rare Barn Burner Aluminum Receiver & Battery Box
Aluminum Case Transmission w/ RRP Gears
Pro-line Performance Steering Kit
Spool w/ RRP Gear
HD Steel Brake w/ Carbon Fiber Pads
Integrated Aluminum Brake
Unlimited Engineering (OFNA?) Flywheel w/ New Aluminum & Composite Shoes
* Also Including two (2) Clutch Bell Gears.
Upgraded Transmission w/ RRP? Gears & Reverse
* Will Include Spur Gear Assembly & Brake Components Too...
Maximizer X75 Wheels w/ New Pro-line Tires
* Note: One (1) Missing Screw.
Set of Differentials (4 screw cases)
* Note: The Differential on Left has a RRP Pinion Gear.
Set of Front or Rear Steel CVD
* Note: No Set Screws.
Set of 4 New Integy HD Shocks MSR8
New Lunsford Titanium Upgrade Kit <4801>
FullForce RC Front & Rear Tubular Aluminum Bumpers
New RPM Front Bumper
Steering Servo Guard (Aluminum)
Center Aluminum Skid Plate
RC Solution Stainless Steel Skid Plate (Rare)
RC Raven Red Nylon Body Posts
Pro-line Extended Run Fuel Tank
Motor Saver Engine Air Filter w/ Pre-Filter
New Lunsford Titanium Motor Mount Screws
New 17mm Aluminum Hexes w/ Wrench
New? Aluminum Fuel Tank Cap w/ Fuel Filter
Also... I have a lot of other components to finish this project. So please PM and/or check my other postings. Thank You for Looking...
Check Out Web Album...
https://picasaweb.google.com/drstati...eat=directlink
