need some help with esc..
Romster
need some help with esc.. - 05.06.2006, 11:06 AM
I am running a set-up with a BK 12020 Esc I have followed the instructions in how to set-up esc. I understand the set-up...
1. turning on esc first beep 5 seconds
2. Move full throttle then after 5 seconds another beep then
3. move to full brake then
4. 5seconds double beep set-up is done.
So what do I do if I am still at the full throttle after 5 seconds and don't here a beep..
Some help!!:002:
squeeforever
squeeforever's Avatar
05.06.2006, 11:07 AM
Did you pull the red jumper?
Sylvester
Sylvester's Avatar
05.06.2006, 11:18 AM
Im sure he did, since its in programming mode...
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Romster
05.06.2006, 11:24 AM
Yes i pulled the red and black jumpier.
Do I have to make any adjustments to my transmitter?
cspurlock
05.06.2006, 11:31 AM
It would be a good idea to have them at 100% EPA and 0 your trim out. Strange though, mine works fine as you described.
Romster
05.06.2006, 11:38 AM
Tried it EPA 100% to 140%...
Still not working.. Still on first beep.
cspurlock
05.06.2006, 11:44 AM
email Mike and see if he can help you. He has proven to be very willing to try and help me out when I had problems.
Romster
05.06.2006, 11:47 AM
OK I do it right now.
thanks,
squeeforever
05.06.2006, 12:04 PM
Sylvester, I wasnt sure because I have had mine beep when the jumper wasn't, ect. I have had some weird stuff happen when i tried to program it.
Romster
05.06.2006, 12:15 PM
Squeeforever, But eventually your Esc worked.
Did it do the same thing as my esc.
What did you do?
Romster
05.06.2006, 12:29 PM
I got it set-up.
I checked my transmitter Throttle and it was in Reverse mode and I programed it back to Normal throttle. An I got all the beeps. So I put back the red jumpier.
So when I turn on the Esc and press throttle the Esc makes these weired sounds and the motor is not turning.
what should I do..
squeeforever
05.06.2006, 12:52 PM
Try and reprogram it again. Also, check all your connections on the motor, ect. I found mine was a loose solder joint on the motor and it wasnt really appearent. I had to check them with pliers and finally found it. And yes, it does work now.
Romster
05.06.2006, 01:35 PM
This is Soooo weird.
When Lehner motor is connected to Esc it does not spin freely.
When Lehner motor is disconnected from Esc is spins freely.
So I tried another motor.. A feiago same thing So I know it's not the motor.
I played with the connection configuration two connections it would spin freely and then 3rd connection it would just slightly tighten up. So weird..........
What should I do??
Tom F
RC-Monster on a Budget
05.06.2006, 02:27 PM
Mine did that - the programming was intermittent to say the least...
Try fiddling with channel reverses - that worked on mine sometimes
http://img513.imageshack.us/img513/3880/dscn1559dp5.jpg
Brushless - How fast do you wanna go today?
  Send a message via MSN to Tom F
Romster
Thumbs up 05.06.2006, 02:35 PM
Guys thank you so much for all your help finally it works.
IT's ALIVE!!!!!!!!!!!!!
Squeeforever thank you. It did the trick I notice I solder the wrong blue wire to the other wire. I guess the 3pairs of blue wire can get a little confusing at times. Thanks again Guys!!!!!!!!!!!!!!:027:
