5s MMM 2200 MT4-g3 BUG VIDEO
Chainsaw10
5s MMM 2200 MT4-g3 BUG VIDEO - 12.24.2011, 08:37 PM
some video from earlier today. This truck is a tank!
[YOUTUBE]Ao-JTLNpeTI[/YOUTUBE]
[YOUTUBE]TrOMRJdXyl8[/YOUTUBE]
BIG-block
12.25.2011, 10:17 AM
Thats some nice flight time man.
12.26.2011, 10:25 AM
That was awesome! I have never before seen an r/c that flip itself back onto it's wheels.
I'm curious. Obviously the arch shape of the bug body helps. Have you taped your tires, or do you think that tire ballooning aids in the r/c righting itself?
el tomaso
12.26.2011, 04:02 PM
I need to learn that trick, I guess I finally have to build a MT with big castle or leopard motor. Now I have buggys mostly.
TG
Chainsaw10
12.26.2011, 11:53 PM
The rounded bug body definitely makes it easier to flip the truck over but I can do it with other bodies also. Even on 4s I can get the truck back up on it's feet. The tires are not taped.... I'm sure the ballooning tires helps but I Would bet it would still flip back up with taped tires.
Chainsaw10
12.27.2011, 12:02 AM
I don't know if you can tell from these pics but the tires actually protrude out further than the front bumper. This also helps when you rock the truck when upside down. They bite into the ground real easy cause they stick out so far.
I'd have thought doing this would've stripped some diff gears by now but I am yet to have any front diff failure! And I've done this countless times.
Chainsaw10
12.27.2011, 12:43 AM
Theres not much elbow room for any real speed here on the side of my house
but its still a fun little spot to bash
[YOUTUBE]aHgI39jKLUM[/YOUTUBE]
this is another one of my MT4-g3 trucks with a summit body on 4s
[YOUTUBE]rq4YvraeMPY[/YOUTUBE]
Chainsaw10
12.27.2011, 10:47 PM
hers a video from earlier today.
my 2 little snots attacking my truck
F-650 body ....4s lipo
[YOUTUBE]b4eIYQ_EvYw[/YOUTUBE]
yzinger02
yzinger02's Avatar
12.29.2011, 05:37 PM
What all have you broken if anything? Cool videos!
Chainsaw10
12.29.2011, 06:27 PM
Broke nothin major and I run my 2 trucks at least 3 to 5 days a week. The stock hinge pins break easily so I've been replacing them one by one with stronger ones as they break. Cracked 2 arms, but not comPlete breaks, made aluminum splints for them(even though I have spares on hand).
One rear diff got a lil crunchy a few weeks ago but I shimmed it tighter and it's still good!! I have 4 diff gear rebuild sets on hand but I like to see how long things can last.
I broke one toe in plastic block and replaced with optional aluminum one from thunder tiger.
This truck is extremely durable...... Every time I run it I am amazed at some of the hits it takes and keeps goin!!I did make my own chassis brace which I'm sure has saved the chassis and shock towers from damage.
I'm not nervous at all about breaking things on this truck because parts are cheap and the truck is extremely simple to work on.
yzinger02
yzinger02's Avatar
12.29.2011, 07:05 PM
Thats impressive! Im surprised the tires haven't blown or the body cracked into pieces. I dont drive my truck near that hard!
Chainsaw10
12.29.2011, 10:42 PM
Oh I have about 5 different bodies I run on these trucks. I like to switchem around often... A few of them are pretty beat up. Tires are holding up great besides a few rips after running into sharp objects... I was able to repair them.
Chainsaw10
01.21.2012, 11:19 PM
a little brushless ice capades break dancing
[YOUTUBE]ljCy991eQvs[/YOUTUBE]
[YOUTUBE]eqzNgVeyG60[/YOUTUBE]
[YOUTUBE]kd7NqzZLFis[/YOUTUBE]
brainanator
brainanator's Avatar
01.22.2012, 12:08 AM
Wow, you can hold that on 2 wheels for a long time....sure the diffs love it :p
Chainsaw10
01.22.2012, 12:10 AM
The diffs don't mind a bit. I've put this truck through a lot worse with almost no diff problems.
