EMaxx Questions/help...
K1RC
EMaxx Questions/help... - 12.29.2011, 11:05 AM
Hi all I have quite a number of questions to put to you intellectuals all involving an Emaxx.
I know there have been many custom maxxes built and they have inspired me to try and make my own so the basic outline I had in mind was:
FLM Chassis...
And thats it
This is where I need your help because I am on a tight budget so need to get this mostly right first time. I need help choosing diffs I don't mind spending money on quality as long as it works and lasts...
If I buy FLM Hybrid bulks I would need 1/8th scale diffs, right? but then to run standard traxxas drive shafts I would need to modify them? Could I run them un-modified with CVD's?
If I bought FLM combo bulks would I be restricted to standard diffs? Is this an issue?
Thats the main ones for now but I'm sure more will be thrown up as I'm new to maxxes, any help would be appreciated, thanks
cmac
cmac's Avatar
12.29.2011, 02:44 PM
If you got the FLM HYBRID "combo" bulks you are not restricted to the stock diffs. You can use 1/8 diffs. You can check out my build for ideas.
K1RC
12.29.2011, 02:51 PM
I thought the "combo" bulks and "hybrids" were different things all together? Thats what it looks like on the FLM website? Maybe I'm just confused
If I go 1/8th scale diffs I'm reluctant to spend major £££ so what would be cheap-ish? Is it Hyper 8 diffs most use?
coolhandcountry
coolhandcountry's Avatar
12.29.2011, 05:34 PM
Combo bulk use stock diffs.
Hybird bulk use 1/8 buggy diffs.
Mike has the shafts to install in the 1/8 buggy diffs to use stock shafts.
Peace!
Country
Help support the
Rc-Monster
Buy here
K1RC
12.29.2011, 05:44 PM
Ah thanks
If I just bought buggy diffs and CVD's would I not need to buy that little shaft or modify them?
coolhandcountry
12.29.2011, 07:35 PM
The cvds will slide in the buggy cups.
No mods required there.
The center needs dog bones though.
Peace!
Country
Help support the
Rc-Monster
Buy here
K1RC
12.30.2011, 09:24 AM
So if I bought to of these: http://www.ebay.co.uk/itm/Hyper-7-8-...#ht_500wt_1202
And some CVD's they would just drop straight into the Hybrid bulks?
Also I found some Proline powerstrokes for $155 and the bypass' are new is this a good deal? I know they're some of the best out there and I love their look
coolhandcountry
12.30.2011, 09:45 AM
That does look like the ones you need.
Peace!
Country
Help support the
Rc-Monster
Buy here
K1RC
12.30.2011, 09:52 AM
Did I read somewhere I have to change the crown gear to make it fit or was that something else completely?
Do you think the shocks are a good deal?
coolhandcountry
12.30.2011, 01:30 PM
I thought that was only on the newer 9 model.
Could be wrong though.
Peace!
Country
Help support the
Rc-Monster
Buy here
K1RC
12.30.2011, 02:59 PM
I guess I'll just have to buy them and find out then!
What CVD's would anyone recommend Losi xxl's? Do they need a modification?
George16
Supermaxx
George16's Avatar
12.30.2011, 04:47 PM
You don't have to change the crown gear.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
12.30.2011, 06:38 PM
Yup, crown-gear change is/was only required if you could only get hold of the truggy diffs with spiral cut teeth, the buggy diffs use straight-cut teeth which is what you linked to.
Don't forget your shims: clicky
K1RC
12.31.2011, 05:39 AM
Ok thanks guys
Any recommendations on CVD's?
01.01.2012, 11:49 AM
I'd say either the traxxas or MIP cvds should be fine, though there is always the option of running LST XXL cvds if you don't mind a tiny bit of modding work:
http://traxxas.com/forums/showthread...=1#post4633281
http://traxxas.com/forums/showthread...=1#post4864749
There are a few ways to make 'em fit depending on which knuckles/bearing carriers you go with, but they are the beefiest option pretty much.
