Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Slipperential parts update
mothman
Slipperential parts update - 01.31.2012, 04:40 AM
I have the old slipperential and the new one (bought used from a forum member) It seems that some of the parts are not the same. The front and back cover is different. The new one is thicker. Aparat from the covers, I am not sure what else Mike has changed. Can you please let us know what are the changes and the reason behind them?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.31.2012, 12:59 PM
When we upgraded the gaskets, we modified the endcaps slightly to compensate for the extra gasket thickness - the new blue gaskets are much thicker, so it affected the gear mesh inside.
mothman
02.02.2012, 01:36 PM
Thanks for the clarification Mike. So meaning that if I have the old version and I want to change the gasket, then I have to change the endcaps as well? I just opened my old slipperential and threw away the gasket as they were kind of worn out.
RC-Monster Mike
Site Owner
02.02.2012, 04:51 PM
Yes, if you use the newer gaskets, it is recommended that you also use new endcaps. It has been over a year(maybe 2 years) since the update, so you may be due for some fresh parts by now anyways. :)
