HV servo pulsing?
JAILBIRD
HV servo pulsing? - 03.09.2012, 08:27 PM
I just got my rig built and the servo is doing something strange. When I turn the wheel on the TX the servo pulses. It repeatedly moves a few degrees back and forth. When I let go of the wheel the servo seems to center fine. Electronics are a DX3R, Losi RX, MMP SCT, and a Hitec 7950TH. I haven't plugged the MMP into a Castle Link yet to make any adjustments. I'm using a fresh charged 3s battery. Does anybody have any thoughts as to what's happening? Thanks.
-JB
jas21373
03.09.2012, 08:46 PM
check the bec voltage
03.09.2012, 09:19 PM
try a novak glitch buster http://www.ebay.com/itm/Novak-Electr...ht_3062wt_1329
Also, setting end points via your transmitter can help.
There just seems to be something up with spektrum and castle setups. I've seen several e-baja guys with this problem. The cap usually fixes it.
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
03.10.2012, 12:25 PM
I have an original Spektrum DX3, and a Castle MMM setup. On the built-in bec it was fine. I later upgraded to the external BEC so I could get the full benefits from my HV Savox servo. Turns as smooth as butter. I don't have any filters or anything.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
JAILBIRD
03.10.2012, 09:39 PM
Thanks for the tips guys. I found a cap in my electronics box so I'll give that a try first. I also found a few BECs so I'll probably end up running one of them to get the most from the servo.
-JB
