What could be wrong with my setup?
Bmr4life
What could be wrong with my setup? - 07.29.2012, 06:05 PM
Trying to figure out why my Jammin CRT .5 is not hitting the top speed it should be according to the online calculator.
Stock 46t spur and stock diffs. 25T pinion. Castle 2650kv motor on 2s and 3s. 4.5" buggy tires.
Calculator says it should go ~44mph on 2s and ~66mph on 3s.
My actual speeds are 28mph and 43mph.
The motors is less than 120F on both packs.
What am I doing wrong?
07.29.2012, 08:56 PM
Tire diam?
Bmr4life
07.29.2012, 09:30 PM
Yeah, I got that correct too. Whats really confusing is the speed are off at the same degree.
The calculator says I should be getting 22mph per 3.7 volts of lipo power.
GPS says I'm getting ~14mph per 3.7 volts.
Bmr4life
07.29.2012, 09:51 PM
Also, on 3s it can pop wheelies from a stand still easily. I don't think its over geared given this and the low temps. Lastly, the batteries should be good for 125amps.
07.29.2012, 10:13 PM
the motor isn't spinning 2650rpm/v then... do a kv check
Bmr4life
07.29.2012, 10:17 PM
How do I do that?
Would this work?
Method 3 (Colin Dedman's formula)
1. Drive the motor with a drill press.
2. Measure RPM and voltage generated (by one phase).
3. Kv = RPM / (volts x 1.41 x 0.95)
your speeds match up to 1650kv. weird.
Bmr4life
07.29.2012, 10:36 PM
So how do I get the kv of a brushless motor?
Update.
Just ordered a RPM-KV meter. Looks like a cool little device.
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.30.2012, 12:09 AM
If you have a castle esc and castle link for pc you can do the kv check, it's part of the procedure for setting up Torque Control.
Bmr4life
07.30.2012, 12:25 AM
Really? Cool. I'll look into that tomorrow. Thanks
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.30.2012, 08:26 AM
What diff ratio does it have?
Bmr4life
07.30.2012, 08:42 AM
3.25 according to the calculator and google.
07.30.2012, 09:09 AM
What are you using for battery voltage on the calc? 3.7v per cell should be the one to use.
Bmr4life
07.30.2012, 09:14 AM
3.7v
Also, its not my first time using the calculator. I've been able to match up my Savage Flux pretty good, its within 3mph.
07.30.2012, 09:38 AM
Try exporting everything and pasting it here. Maybe there's just something being overlooked...
