Closed Thread
Losi 5ive Brushless Conversion Parts. Castle Creations 2028 motor, 4s lipos, RCM BL5
Bmr4life
Losi 5ive Brushless Conversion Parts. Castle Creations 2028 motor, 4s lipos, RCM BL5 - 08.03.2012, 06:32 PM
Send me a PM if interested.
First up is the humongous Castle Creations 2028 1/5 brushless motor. Its used, but it very good shape. Worst looking part on it is the shaft which shows the normal wear from pinion grub screws. I just soldered on brand new CC 8.0mm bullets and I'm including the other matching half for you to attach to the esc of your choice. Motor also includes the dual fan cooler.
Next up is the best conversion setup out. The RCMonster BL5 set. It allows you to keep mechincal brakes which is almost a necessity to keep motor temps down and would allow you to use a boat or air esc since the motor would not be doing the braking. Also includes two MOD 1.5 pinions, 14t & 16t.
Last is a pair of Venom 4s 5000mah 35c hardcase Roar Approved lipos. Model number 15027. These cost $100 each at towerhobbies. They've seen 3 cycles and could pass for new if it weren't for the crack in the case on one of them. The lipos have a ton of foam padding on the inside and in perfect shape. I was going to tape a piece of thin sheet metal over this area, but I wanted everyone to be able to see the hole before I did so. Both batteries have EC5 connectors for super high current handling and JST-XH balance plugs.
Closed Thread
