Motor Pictures
yamil
Motor Pictures - 10.27.2012, 07:57 PM
I'm converting an XT8 to electric and got my parts from Mike (Awesome products by the way). Since there's no instructions and I'm a neebie with electrics convertions, I'm requesting a close up picture of the front part of the mounted motor. I just want to see the bolt locations. Thanks
10.27.2012, 08:36 PM
The only thing changing bolt holes on a motor does is effect where the wires exit the rear.
It doesn't matter which bolt holes you use, or where the wires exit. There is no instruction for this.
Just use whichever bolt holes make the wires work well on your vehicle.
I hope this makes sense.
yamil
10.27.2012, 08:56 PM
makes perfect sense. I was just wondering because the motor bolts straight to the mount
Kcaz25
Kcaz25's Avatar
10.27.2012, 09:57 PM
Also you can remove the end cap, rotate it and put it back if the position of the holes weren't right at first.
electric
electric's Avatar
11.19.2012, 04:15 PM
Post thread of this in the truggy section when your done I would like to see your setup. I'm fixing to be doing a XT8 build myself.
Wil
War Damn Eagle
mounted motor
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
mounted motor - 11.19.2012, 10:09 PM
Does this help?
ID:	10541   Click image for larger version
