Hot Servos.. What the????
jhautz
jhautz's Avatar
Hot Servos.. What the???? - 05.24.2006, 01:43 AM
Man I am just running into one thing after another here lately.. Im working on setting up my revo with a new brushless setup that I bought ot replace my old setup, that was not big enough for the truck.
Now when I plug the battery in and test function of the ESC and servos, the stering servos start to get hot real fast and Im not even using them, then one starts to twitch. I pulled the battery when that started to happen, cuz I figured it was onn the verge of doing some damage if I didn't.
Now, why would the stering servos overheat? The shifter servo is fine and Im using the tiny little one for that. I double checked all of the wiring and plugs and all is in order as far as I can tell. Nothing backwards or anything.
Here is my setup I used for the bench test when the servos were overheating:
Quark Monster125 esc (new first test), Feigao 9xl(new first test), UBEC 6V CAR(new first test) , 3S (11.1v) Lipo pack, Stock Traxxas 2055 servos, Spektrum Reciever and DX3 radio.
The center red wire was disconected from the esc to the reciever to eliminate the BEC on the controller.
What I did was do the basic programing routine for the esc, test the motor and esc for basic function, and adjust the servo travel and the linkage for the shifter servo. Thats when I noticed the stering servo was hot and was starting to twich a little. I tested the stering and it was fast and seemed to work fine. so I kept an Eye on it for another minute or so and the twiching got worse and the servos got hotter. One servo got hotter than the other and it seemed to be the one doing the twitching.
Im not quite sure what that means. Is the UBEC putting out to much voltage for the servoes. It says its a 6v bec. I would think that should be fine. I didn't have any issues with the sevoes when I had my old system in it. It was running on an older 5v UBC unit though. The servos are basically new with only maybe 5-6 runs on them.
Any Ideas?
( I realize that this might not be the ideal forum for this question, but I couldn't find a forum that fit and I figured since I ran into this issue while setting up a new brushless system...)
coolhandcountry
coolhandcountry's Avatar
05.24.2006, 07:52 AM
Was the servo under a bind from something? Cause sitting still it will try to center the tires and it is hard to move on a surface when you not moving. you would need a voltage checker to see if it is over voltage.
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
05.24.2006, 08:18 AM
Hey jhautz, here's what I would do:
-check if the UBEC is really giving 6V
-make sure the servos are not fighting each other.
If you are sure on the voltage, and the servo centers are fine, then disconnect the servos from the steering assembly and try if you still have the same problem. If yes, you might just have a bad servo. Would be a good opportunity to upgrade to a single servo.
neweuser
neweuser's Avatar
05.26.2006, 05:15 PM
What i did one time is plugged it in backwards and it got hot like that....jsut an idea....so the sig wire was in the neg spot and vice versa! ooops.
jhautz
jhautz's Avatar
05.27.2006, 03:19 PM
Thanks for all of the sugestions. Turns out I didn't have them adjusted to each other just right and they were fighting each other. putting a constant load on them. Got it straightend out now.
coolhandcountry
05.27.2006, 04:29 PM
Cool. Glad you got it straight. Did you get a test run in?
Peace!
Country
Help support the
Rc-Monster
Buy here
jhautz
jhautz's Avatar
05.31.2006, 09:16 PM
Yea. I took it out over the weekend and blew the plastic idler gear in about 15 seconds. The sttel ons are on the way from mike now. I was going to oder themsooner, but both mike an UE were out of stock on them and when I blew the plastic I saw that they were back in stock here. So... I should be ready fro test run #2 this weekend.
