Lipo Charging ?
Mark Fradkin
Rad Frad
Lipo Charging ? - 05.27.2006, 12:19 PM
Mike "of coarse" Set me up with The multiplex charger, power supply & Apachee 5s (2packs) but I have some charging Questions.
Under the "LIPO" charge Batt type
Lipo charge I put 3700mah 18.5Vpc
Lipo discharge I put D= ? A 18.5Vp
I am unclear as to what discharge rate to use. The 5s apachee says on the packs 55a max discharge. Does anyone know?
Mike suggested the Hyperion 2-5 cell balancer to order directly which I have not recieved yet.
Also Mike is seting me up w/ LVC which I Have not recieved yet. Should I wait for the LVC so I do not mess up multi$ batteries?
Thanks Mark
MetalMan
MetalMan's Avatar
05.27.2006, 01:59 PM
Don't worry about the discharge rate. That's only if you discharge the battery, but that is unnecessary.
The Hyperion LBA6 balancer works well.
It could potentially be easier on your wallet if you wait for the LVC to arrive.
