05.10.2013, 10:45 PM
What's 40x75? What is 42/50 mean?
As far as what brand of motor you should use, check out Scorpion brushless motors, IIRC, the 40xx S2's are the newest (not even sure if they are out yet) and have been designed with the best high temp. magnets, high temperature wire and small mil core material thickness (0.2mm stator steel). These things are very efficient and just as important, they will be tough.
