Speed calc says you are geared for 70+mph and 50k RPM on the motor. I'd say that's overgeared and too much voltage for the motor. Even with lower gearing Castle recommends 4S max on the 2650kv. The 1800kv 1512 is much better suited for 5-6S.
I will try smaller. Speed calculator said 80+ on a fresh charge.... No wonder it never stopped accelerating!
The holes I cut in the body helped a lot, focused the air over the motor.
