MMP Sensor board
Jony Nitro
Jony Nitro's Avatar
MMP Sensor board - 09.05.2013, 03:03 PM
Hi guys my MMP just stopped working, but its out of warranty, by about 3 month, I think its the sensor board, have all the lights working no motor out put in either mode.
who can I contact thanks guys
D8T Brushless
Brushless Baja
SC10 Neu Power
09.05.2013, 07:52 PM
Castle
Jony Nitro
Jony Nitro's Avatar
09.06.2013, 05:22 AM
I gathered that!
I just meant sometimes castle comes on here, so like price wise for a new unit,and email contact. Thanks for your input
D8T Brushless
Brushless Baja
SC10 Neu Power
Pdelcast
Pdelcast's Avatar
09.09.2013, 09:35 AM
Originally Posted by Jony Nitro View Post
I gathered that!
Hi Jony,
Check a couple things first--
1. Make sure the sensors in the motor are working -- try it with another motor, or try the motor with another ESC.
2. Make sure the controller is in "sensored" mode.
3. Make sure the controller is calibrated correctly.
4. Do you get motor beeps?
5. Try the controller in "sensorless" mode. Does it work?
If all fails, you can do a non-warranty here:
http://www.castlecreations.com/support/repairs.html
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
Jony Nitro
Jony Nitro's Avatar
09.09.2013, 11:08 AM
No beeps, tried my new SP 7.5 not worked, yes I did switch it over on the settings to sensored, then switched back. and yes recalibrated it, and used two different RX/TX combo
D8T Brushless
Brushless Baja
SC10 Neu Power
