Hyperion 610 Duo and smc 2s2p hardcase packs.
FG101C
Hyperion 610 Duo and smc 2s2p hardcase packs. - 07.28.2014, 12:16 AM
It's been a while since I've been on here but I figured you guys would probably have an answer.
I have had a Hyperion 610 duo for about seven years now and love it. It has always worked perfectly on various packs I've had. I just recently started running 1/10th and am using typical hard case 2s2p 2s packs.
Well my Hyperion takes a good two to three hours to charge them. This is with a variety of brands. I have a cheap little IMAX charger that charges them in 20 minutes.
What I've noticed with the Hyperion is if one cell is higher than the other it drops to .5 amp and from what I can tell discharges the higher voltage cell, slooooooowwwlly, to match the other then start charging.
My question is there something I'm missing, a setting, or is that the way the Hyperion is set up?
Thank you.
