Wich battery tray for Losi Muggy?
ruudxd
Wich battery tray for Losi Muggy? - 11.28.2014, 06:12 AM
Hello,
I am looking for a new battery tray for my Losi Muggy with IRC chassis.
I think it has a Losi 8ight tray now, see this picture:
The ESC is on a plate that is attachted to the tray, so it is not the one shown on the site from IRC.
But I am looking for a tray wich is about 55mm wide and 150mm long or longer ( inside dimensions ofcourse )
And I like the idea of having the ESC on a plate to, not directly on the chassis.
Wich one would be the best for me?
Because on the tray for the IRC chassis are no dimensions?
Thanks in advance!
Ruud
11.28.2014, 10:16 AM
Just order a custom one from mike and specify what you want
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.28.2014, 12:30 PM
I actually make a battery/esc tray specifically for the IRC Muggy chassis.
ruudxd
11.28.2014, 04:20 PM
Yeah, I saw that, but I do not see the dimensions of it?
And if I let you make one, I guess I need to drill the holes in it myself?
RC-Monster Mike
Site Owner
11.28.2014, 04:26 PM
The tray has the same 4 hole pattern as the IRC chassis - I borrowed a chassis to make the tray for it(the E-chassis of course), so it is a direct bolt on fit. The actual battery area is pretty large - around 55mm wide by around 170mm long
ruudxd
11.28.2014, 04:48 PM
Are those the inner dimensions?
That would be great!
I knew it would be a bolt on option, but I meant to drill if you made a costum size one.
Thanks again!
Ruud
RC-Monster Mike
Site Owner
11.29.2014, 12:00 AM
Those are the inner dimensions in the battery compartment(battery size capability).
ruudxd
11.29.2014, 11:45 AM
Ok, thanks a lot!
I will order one asap then!
Thanks again for all your patience!
