Recommended grease for E-maxx Transmission
BlueJuice
Recommended grease for E-maxx Transmission - 06.02.2006, 03:17 PM
I've got a SuperMaxx Hardened Steel Idler Kit coming and i read on their web site that they recommend using grease in the transmission and not to run it dry, anyone recommend a good grease to use?, I'm only using the stock motors at the mo.
neweuser
neweuser's Avatar
06.02.2006, 04:59 PM
i run a light bearing grease that works very well. No need to use too much though.
BlueJuice
06.06.2006, 02:50 PM
Thanks, i'll try some.
neweuser
neweuser's Avatar
06.06.2006, 02:52 PM
Just make sure it's light so it's not too thick and you'll be fine.
BlueJuice
06.06.2006, 03:06 PM
Would Tamiya anti wear grease be too think?
Serum
Serum's Avatar
06.06.2006, 05:19 PM
Best grease is the black/grey moly grease.
I use a wax based grease in mine.
BlueJuice
06.08.2006, 05:06 AM
cool cheers, you could'nt give me the name of the grease could you, see if i can find it. Ta
Papa
Papa's Avatar
06.08.2006, 06:59 AM
http://www2.towerhobbies.com/cgi-bin...2&I=LX2880&P=K This is the stuff I have used and have been very happy with it.
Serum
Serum's Avatar
06.08.2006, 07:00 AM
Moly grease is the name.. I found some of Castrol here.. Towers sells this set of different greases/oil.. Always good to have..
neweuser
neweuser's Avatar
06.08.2006, 08:57 AM
Yep, moly grease is good.
