What lipo brand should I buy?
What lipo brand should I buy? - 06.07.2017, 07:38 PM
Yes, you read it correctly, the rc lipo repair man himself (back in the day, check yourself before you wreck yourself, aaiight..) needs some info from those in the know.
I need to replace some of my smaller lipos, due to them not being used for 6yrs or so...
Looking for a hardcase 3000 mah or larger 2s pack that will fit in the saddle location of my tamiya M03, so it needs to be shaped like a good ole stick pack, oval in cross section.
And I am sure I will need another 3s 5000mah pack.
Brands, where to get them, prices, all will be greatly appreciated!
Kcaz25
Kcaz25's Avatar
06.07.2017, 07:51 PM
Hobbyking is still good for me. You know where to get them. Hyperion is still elite for me$$$. Get those at allerc.
Apperantly graphene substrate is a thing now and some packs have higher than normal voltage. Like 4.35v. I havent tested either of these.
06.08.2017, 09:16 AM
I hear great things about maxamps.
06.08.2017, 10:10 AM
From Maxamps, I am sure...
I made the original order that allowed my LHS to be a distributor and get "better" prices from Maxamps. I puffed every pack I bought within the first 6 weeks of ownership.
06.08.2017, 10:22 AM
Prices on the hyperion packs seem to have dropped quite a bit, IIRC. I may have to skip the cheapos.
Kcaz25
Kcaz25's Avatar
06.08.2017, 10:28 AM
Yeah they have. They are the best. Also amazon carries gensace people used to love them. They were good quality and cheap. https://www.google.com/url?sa=t&sour...h04n7zDLqMB2MQ no idea if it will fit.
06.08.2017, 12:18 PM
Pack puffing I thought was just break in when the pack expands to add extra capacity.
Kcaz25
Kcaz25's Avatar
06.08.2017, 01:12 PM
Its a feature. It actually is a helium release so that the vehicle becomes lighter.
06.08.2017, 01:49 PM
My favorite Maxamps experience was using their 10,000mah 3s lipo. I ran it in a 2wd pede geared for about 45 mph. Runtime was lower than expected and the pack was so out of balance it took about 40hrs to balance. I tried to send it back, no dice.
06.08.2017, 01:50 PM
Yup, plus it helps the shrink hold the cells together better than the cheap brands.
ruudxd
06.08.2017, 03:29 PM
If I recall correct that was also act as a cushen to protect the cells in jumps etc?
06.09.2017, 11:03 AM
And helps custom fit the pack to the battery tray. You don't just get a lipo when you buy maxamps, you get peace of mind in knowing you made the best decision.
I should be on their PR team...
nitrostarter
nitrostarter's Avatar
06.14.2017, 09:27 PM
Not sure they have the size you want but check out SMC. They're quality has seemed to go up and they are well trusted in the crawler market.
I run Turnigy still but did pick up a Gensace 3s 2200 recently. Haven't run it yet but it looks good from afar.
N. Rustler conversion
ruudxd
06.16.2017, 05:49 PM
You don't get just LiPo or You just don't get a LiPo?
You get everyting else, just not a good LiPo :)
I have good expierence with Gens Ace as well, the customer service in Germany is very good as well.
06.20.2017, 09:34 PM
I picked up 2 gens ace hardcase 2s 5k from ebay. seem to be doing well.
I also found a stick pack shaped 5100 2s lipo that fits in my Tamiya M03. Says it can do 35c, Kinesis is the band IIRC. We shall see how it does...
