Originally Posted by Mike.L
why for a mini-t the truck only takes low Mah. like 1500's and not 3300's know what i mean.
It's a matter of size due to energy density. Both nimh and lipo can fit a fixed amount of power in a fixed size.
Take IB (Intellect Battery) nimh, for instance. The standard sub-c size cell can hold 4200mah of power in that size cylinder. The 2/3A size cell is physically a smaller cylinder that will only hold 1200mah of the same power, simply because you can only fit a certain amount of power within a certain space.
If the Mini-T had the room to mount a sub-c size battery pack, you could definitely use 3300mah cells. It just lacks the physical space for it.
Hope that helps.
