BK 12020 Problems
giftacrylic
RC-Monster G-Maxx
giftacrylic's Avatar
BK 12020 Problems - 06.17.2006, 12:30 AM
Installed a new 12020 controller with a 8XL motor and the throttle seems very exponential instead of linear (it appears to have very little torque). Most of the throttle is useless when accelerating, only the last 1/4 max throttle really makes the truck move fast. When the truck is traveling at high speeds, I jab the throttle (about 1/2 throttle) and the truck has little or no response.
Things I have done:
1. Tried 3 radio systems
2. Cut wire and re-soldiered the system
3. Moved electronics so there will be no interference
4. Always reprogrammed the controller after every step
5. Tried several sized pinions
Could I have rec'd a bad controller?
tallyram
tallyram's Avatar
06.17.2006, 01:38 AM
my 12020 is kinda like that. the last quarter of throttle is like a huge turbo kicking in. the 20120 is programmable, but the 12020 is not. oh well.
  Send a message via AIM to tallyram
giftacrylic
RC-Monster G-Maxx
06.17.2006, 08:08 AM
That is how my system operates and it is difficult to drive on a track. I have very bad low end throttle response as compared to my nitros. It is very hard to navigate triple double jumps when there is little torque.
Romster
06.17.2006, 09:23 AM
I have the BK 12020. I have no problems with it. Runs like a nitro 1/8 buggy accelerates great lots of torque and brakes fine..
I run a Lehner 1950 6turn...
Maybe try a different motor...
hope this helps.
tallyram
tallyram's Avatar
06.17.2006, 10:01 AM
i run a 1950/8 with 6s lipo? i got used to the way it accelerates.
giftacrylic
RC-Monster G-Maxx
06.17.2006, 10:05 AM
I had a 9920/7XL and the throttle was linear, I had instant power when needed. That is what I expected with the new system, just a little less power w/ added runtime. The new setup acts completely different.
Very dissappointed.....
squeeforever
squeeforever's Avatar
06.17.2006, 11:56 AM
Maybe you can change it with the programming cable?
coolhandcountry
coolhandcountry's Avatar
06.17.2006, 03:03 PM
If the esc is in non car mode. It will have a funny throttle curve. The warrior and micro can both be in non car mode.
Peace!
Country
Help support the
Rc-Monster
Buy here
tallyram
tallyram's Avatar
06.17.2006, 06:15 PM
how do you switch the warrior to car mode?
coolhandcountry
06.17.2006, 06:28 PM
program cable.
Peace!
Country
Help support the
Rc-Monster
Buy here
tallyram
tallyram's Avatar
06.17.2006, 07:21 PM
i thought i read a post that said warriors were non programmable? is the software mac compatible?
Serum
Serum's Avatar
06.17.2006, 07:46 PM
Nope, it's not..
It uses a parallel port too (don't know what mac you've got, but the newest don't have got a parallel port anymore) and i don't trust those usb>lpt converters.. Come to think of it.. What controller uses mac compatible software.. Castlecreations doesn't either..
giftacrylic
RC-Monster G-Maxx
06.17.2006, 07:56 PM
I set my forward throttle EPA on my radio up to 125 and that gave me the instant power that I expected. In any way can this damage my system?
Serum
Serum's Avatar
06.17.2006, 08:00 PM
No, it should not damage your system, (it's not that the voltage gets higher or anything, it works with small pulses) but can you try reprogramming it with this new setting?
you never know..
giftacrylic
RC-Monster G-Maxx
06.17.2006, 08:13 PM
Thanks for the input, the final test will be tomorrow at the track.
