lipos for my emaxx
toby
toby's Avatar
lipos for my emaxx - 06.21.2006, 05:16 PM
I need some lipos have NO idea what i am looking for. here are my specs
20120 speed control
10xl motor (or bigger i am buying a new one soon)
8 spider diffs
single speed with steel idler
rc18mt/blade cp
squeeforever
squeeforever's Avatar
06.21.2006, 05:17 PM
It depends on if your looking for runtime or speed. How long do you need to run?
toby
toby's Avatar
06.21.2006, 05:43 PM
a tad of both. i want 30 minute run times minimum
rc18mt/blade cp
squeeforever
06.21.2006, 05:44 PM
I would say 8000mah 6S lipo would be awesome. And probably over an hour runtime.
toby
toby's Avatar
06.21.2006, 06:20 PM
OMFG. what kind of speed should i be getting? and exactlly what motor should i get ( cannot spend alot on my motor)
rc18mt/blade cp
toby
toby's Avatar
06.21.2006, 06:44 PM
also how long do lipos last. if i charge and discharge and all of that. what should be the life on these?
rc18mt/blade cp
squeeforever
06.21.2006, 07:00 PM
I would say 55+ on 6S lipo with the 10XL. It really depends on exactly how well you take care of them. BTW, you don't discharge LiPo's like NiCad.
toby
toby's Avatar
06.21.2006, 07:30 PM
if i followed by the book instructions on how to take care of them?
rc18mt/blade cp
squeeforever
06.21.2006, 09:39 PM
It would depend on MANY things. How fast you charge then, how often you balance them, ect. And the biggest....the QUALITY of the cells. Theres really no telling. However, I would say, a couple hundred +
toby
toby's Avatar
06.28.2006, 02:42 PM
what batteries should i purchase than. from what company and all of that?
rc18mt/blade cp
neweuser
neweuser's Avatar
06.28.2006, 02:49 PM
Is that 6s2p in series? or just one 6s? Just curious...
squeeforever
06.28.2006, 05:14 PM
I would recommend 2 3S2P in series.
toby
toby's Avatar
06.29.2006, 09:44 AM
do i need to wire them myself? i am not good with that kind of stuff. only soldering plugs lol!
rc18mt/blade cp
neweuser
neweuser's Avatar
06.29.2006, 09:49 AM
Actually, if you can solder plugs, wires are easier, just make sure you tin them before soldering together. someone here should be able to direct you to a wiring diagram....if your talking about batt packs, you should be able to choose preassembled packs or loose cells....
neweuser
neweuser's Avatar
06.29.2006, 02:53 PM
Ok, is this the 3s2p that would work? 11.1 volts 159.99? http://www.maxamps.com/index.html?la...d=38892.783403 Is this the price for two packs?
Obviously, i would need a new controller because i run the 9920, like maybe 12020?
