7xl preformace -
07.07.2006, 03:52 PM
i was woundering what kind of preformance i can expect with the Feigao 540C XL Brushless Motors 7xl in an e-maxx with the warriour 9220
07.07.2006, 04:03 PM
What batteries will you be using with it? How many cells?
07.07.2006, 04:06 PM
ib4200 12 cells
07.07.2006, 04:17 PM
The 7XL is rated at 2382kv so with good cells at say 1.2v per cell (per their website) you would get a no-load speed of 34,300 rpm. That compares to a no-load speed of approximately 19,000 for the stock tritons. The torque difference and "punch" will be astounding as will the top speed. Top speed should be around 48-50mph.
Cool hand or Squee can correct me here if my calculations are off at all.
07.07.2006, 04:34 PM
what gearing would i run and do you have the motor
07.07.2006, 04:36 PM
I'm going to defer that question to "RC-Monster" Mike. He has a way to calculate the preferred gearing. I'd hate to steer you to the wrong pinion. I will tell you that the preferred set-up is to go with the UE/Strobe Slipper which I believe is a 51T spur gear. This slipper handles the power the 7XL will dish out.
07.07.2006, 04:45 PM
Id start with 18/51 with a 7xl on 12 cells.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
07.07.2006, 04:50 PM
What diffs are you running?
What kind of tire you running as well?
Peace!
Country
Help support the
Rc-Monster
Buy here
I agree with Sylvester. 18/51 would be a good start. If it runs real hot, you can always gear it down. And yes, it depends on the diffs.
07.07.2006, 05:52 PM
i run stock diff and bowtie tires
07.07.2006, 05:55 PM
I would seriously consider upgrading the diffs! You'll likely blow them to pieces with the new power especially landing off jumps when "on the throttle".
1) Install FLM or Kippster difff cups w/ robinson racing gears and GA diff cases
or
2) Do the UE 6 or 8 spyder diffs. Expensive but bulletproof.
07.07.2006, 06:01 PM
i have some titanium ones shiping to me
07.07.2006, 06:04 PM
Ti diff cups? Diff housings?
07.07.2006, 06:05 PM
You do have MIP ur UE CVD's right? Anything else will likely "grenade".
07.07.2006, 06:11 PM
housing and mip cvd
